ADC Help
Stampers:
I 'am experimenting with a BASIC STAMP 1 and a LTC1298 A/d converter.
The program seems to display reading but they are not voltages.
How can I display voltages from 0 to 5 volts on the Debug screen using the program below?????
thanks - tom
' Voltmeter. bs1
SYMBOL CS = 0 ' Chip select; 0 = active.
SYMBOL CLK = 1 ' Clock to ADC; out on rising, in on falling edge.
SYMBOL DIO_n = 2 ' Pin _number_ of data input/output.
SYMBOL DIO_p = pin2 ' Variable_name_ of data input/output.
SYMBOL ADbits = b1 ' Counter variable for serial bit reception.
SYMBOL AD = w1 ' 12-bit ADC conversion result.
SYMBOL sglDif = 1 ' Single-ended, two-channel mode.
SYMBOL msbf = 1 ' Output 0s after data transfer is complete.
SYMBOL oddSign = bit0 ' Program writes channel # to this bit.
high CS ' Deactivate the ADC to begin.
Again: ' Main loop.
For oddSign = 0 to 1 ' Toggle between input channels.
gosub Convert ' Get data from ADC.
debug "ch ",#oddSign,":",#AD,cr ' Show the data on PC screen.
pause 500 ' Wait a half second.
next ' Change input channels.
goto Again ' Endless loop.
Convert:
low CLK ' Low clock--output on rising edge.
high DIO_n ' Switch DIO to output high (start bit).
low CS ' Activate the 1298.
pulsout CLK,5 ' Send start bit.
let DIO_p = sglDif ' First setup bit.
pulsout CLK,5 ' Send bit.
let DIO_p = oddSign ' Second setup bit.
let DIO_p = msbf ' Final setup bit.
input DIO_n ' Get ready for input from DIO.
let AD = 0 ' Clear old ADC result.
for ADbits = 1 to 13 ' Get null bit + 12 data bits.
let AD = AD*2+DIO_p ' Shift AD left, add new data bit.
pulsout CLK,5 ' Clock next data bit in.
next ' Get next data bit.
high CS ' Turn off the ADC
return ' Return to program.
thanks - tom
' Voltmeter. bs1
Again: ' Main loop.
Convert:
The data you receive from an ADC represents the value of the input voltage related to the reference. For a 12 bit ADC, the values can be from 0-4095. 0 of course is 0 volts and 4095 would be when the input is equal to the reference.
If you have the reference tied to 5 volts, then the voltage being read is (ADC value/4095)*5. You will need to deal with the decimal values as your needs demand.
Hope this helps.
