Damaged Demo Board
What is Parallax's policy on damaged demo boards because while adjusting an rca cable the audio port on my demo board all but tore off for unknown reasons. I would fix it my self but some of the metal pads actually tore off of the fiber glass board and I can not solder the connection back.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Trezitorul: Can you place small wires to fix the torn tracks. If so, do that carefully and check it works, then put a small dob of araldite to the connector to hold it to the pcb firmly. Only use a little bit first, ensuring none gets on the actual connector where you plug it in. You can always add a bit more when it is stable.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
If you have a small tip soldering iron, some flux, and a steady hand you can fix it.
As I remember there are four resistors that connect to the RCA jack. You may need to series the wire, and connect it, but it can be done. Not for the faint of hear though. those parts as I remember are 0402's, and are easily lost if you accidentally melt the solder on both sides.
Just an idea.
I would think they would need to send you a whole new setup. It is not an easy fix for them as well. They are not going to solder a jumper on a board, and send it back.
I would say, go with the half price option if you do not solder a lot.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Yea, I wouldn't even try 0201's. Forget anything smaller.
James L
James L
Partner/Designer
I have a "Pick and Place" and don't like 0402's. If the machine misses one, it is hard to find the missing one on a densely populated board.
James L
James L
Partner/Designer
