Need help calling variables in more than 1 cog
Are there any limitations to calling methods from one cog to another and are there any limitations to calling variables throughout the program?
We have IR sensors with an ADC that are supposed to be on a separate cog from the rest of the program so we will be able to continuously monitor them. Our main code will determine what to do once the information is gathered from the ADC. We are having trouble getting the value for each sensor variable to transfer to our main program.
Here is our code:
CON
_clkmode = xtal1 + pll16x ' enable external clock and pll times 16
_xinfreq = 5_000_000 ' set frequency to 5 MHZ
ON = 1
OFF = 0
OUTPUT = 1
INPUT = 0
'Seven Segment Display Pin Numbers.
DISA = 22
DISB = 21
DISC = 20
DISD = 19
DISE = 18
DISF = 17
DISG = 16
'EEPROM Pin Numbers.
SCL = 28
SDA = 29
'Program Switches
PZERO = 0
PONE = 1
PTWO = 2
PTHREE = 3
PFOUR = 4
'Analog to Digital Converter
ADC_CLK = 5
ADC_DIN = 6
ADC_CS5 = 7 'Should be 7, but 2 for development work
ADC_CS6 = 8
ADC_CS7 = 9
ADC_CS8 = 10
ADC_CS9 = 11
ADC_CS10 = 12
ADC_CS11 = 13
ADC_CS12 = 14
var
long front_right
long front_left
long back_right
long back_left
long rightside_front
long rightside_back
long leftside_front
long leftside_back
long inc
long counter
long stack[noparse][[/noparse]20]
long sensor
pub main
i_o_setup
cognew(Read_IR_Sensor,@stack)
waitcnt(40_000_000+cnt)
REPEAT
IF INA[noparse][[/noparse]PZERO]== 0
Outa[noparse][[/noparse]16..22]:= %0111111
waitcnt(80_000_000+cnt)
HeadtoHead
ELSEIF INA[noparse][[/noparse]PONE]== 0
Outa[noparse][[/noparse]16..22]:= %0000110
BacktoBack
ELSEIF INA[noparse][[/noparse]PTWO]== 0
Outa[noparse][[/noparse]16..22]:= %1011011
SidetoSideOppDir
ELSEIF INA[noparse][[/noparse]PTHREE]== 0
Outa[noparse][[/noparse]16..22]:= %1001111
SidetoSideSameDir
ELSEIF INA[noparse][[/noparse]PFOUR]== 0
Outa[noparse][[/noparse]16..22]:= %1100110
Pub HeadtoHead
Repeat
case front_left ' front_right 'If detected stay full speed
0..440: 'displays a zero
outa[noparse][[/noparse]16..22]:= %0111111
outa[noparse][[/noparse]15]:=0
outa[noparse][[/noparse]25]:=0
441..880: 'displays a one
881..1320: 'displays a two
1321..1760: 'displays a three
1761..4095: 'displays a four
other: 'displays a five
Outa[noparse][[/noparse]16..22]:= %1101101'
return
pUB Read_IR_Sensor
i_o_setup
front_right:=0
front_left:=0
back_right:=0
back_left:=0
rightside_front:=0
rightside_back:=0
leftside_front:=0
leftside_back:=0
repeat
outa[noparse][[/noparse]23]:=1
leftside_front:=read_adc(ADC_CS5)
front_left:=read_adc(ADC_CS6)
leftside_back:=read_adc(ADC_CS7)
back_left:=read_adc(ADC_CS8)
back_right:=read_adc(ADC_CS9)
rightside_back:=read_adc(ADC_CS10)
rightside_front:=read_adc(ADC_CS11)
front_right:=read_adc(ADC_CS12)
outa[noparse][[/noparse]23]:=0
waitcnt(80_000_000 + cnt)
PUB read_adc(CS_PIN)
'All IR Sensors
OUTA[noparse][[/noparse]ADC_CLK]:=0 'ADC Clock off
OUTA[noparse][[/noparse]CS_PIN]:=0 'Bring Chip Select low (active)
repeat 5
counter:=cnt 'just a delay, no other purpose
OUTA[noparse][[/noparse]ADC_CLK]:=!OUTA[noparse][[/noparse]ADC_CLK] 'ADC Clock on
inc:=11 'start at 11 and go to 0, 12 bits
sensor:=0 'initialize the variable
repeat 12 'repeating 12 times because there are 12 bits that we are shifting in
if (INA[noparse][[/noparse]ADC_DIN]==1) 'if the bit is a one
sensor:=(sensor+(1<<inc)) 'adds the decimal value of the binary bit using <<inc (first bit is 2048, second 1024, etc)
inc:=inc-1 'decrement the inc variable
OUTA[noparse][[/noparse]ADC_CLK]:=1 'ADC Clock on
'OUTA[noparse][[/noparse]ADC_CLK]:=1 'ADC Clock off
OUTA[noparse][[/noparse]CS_PIN]:=1 'Bring Chip Select high (inactive)
return sensor
[noparse][[/noparse]code]
Post Edited (HayONU) : 4/13/2009 10:11:24 PM GMT
Here is our code:
CON
ON = 1
OFF = 0
OUTPUT = 1
INPUT = 0
DISA = 22
DISB = 21
DISC = 20
DISD = 19
DISE = 18
DISF = 17
DISG = 16
SCL = 28
SDA = 29
'Program Switches
PZERO = 0
PONE = 1
PTWO = 2
PTHREE = 3
PFOUR = 4
ADC_CLK = 5
ADC_DIN = 6
ADC_CS6 = 8
ADC_CS7 = 9
ADC_CS8 = 10
ADC_CS9 = 11
ADC_CS10 = 12
ADC_CS11 = 13
ADC_CS12 = 14
var
long front_right
long front_left
long back_right
long back_left
long rightside_back
long leftside_front
long leftside_back
long inc
long counter
long sensor
pub main
i_o_setup
REPEAT
HeadtoHead
BacktoBack
SidetoSideOppDir
SidetoSideSameDir
Pub HeadtoHead
Repeat
return
pUB Read_IR_Sensor
i_o_setup
front_right:=0
front_left:=0
back_right:=0
back_left:=0
rightside_front:=0
rightside_back:=0
leftside_front:=0
leftside_back:=0
repeat
'All IR Sensors
repeat 5
return sensor
PG
Your waitcnt in Read_IR_Sensor would be better if you used clkfreq instead of 80_000_000. That way, if you change your clock speed you don't have to edit your code so much (like in this statement).
your stack is also pretty small. Why not try changing it to something like 200? You probably have the space to be generous.
Try posting your full code as an attachment.
HayONU, you're new to these forums so, first of all, welcome! I'm sure you'll find the help you need here. In the future, though, please do not duplicate your posts in different forums. It's against the rules. Thanks.
