ENC26J80 Info Needed..
I have just purchased a YBOX2, and want to mod it to add a SD card reader, so I have been on all of the usual propeller sites doing research and it has only brought me more questions, namely are all of the pins used for the network interface.
Scouring the net the developer(s) of the NIC interface and code seem to use almost the same usage either 5 or 4 pins on the propeller, where 5 pins seems to be the most used interface.
The YBOX2 uses 8, one of these being used as a software clock signal (p7 on the propeller instead of a 25 mhz crystal ) which I understand but looking through the code on Dev's (DeepDarc / Darco's ) code repository, I can't find where ( P0 - RESET ) and (P6 - WOL ) are being used.
I would like to recover the use of these pins but still use Dev's code, because his driver has PING and DHCP where the other examples don't.
All this being said, I am worried that re-using these pins will cause the drivers not to work.. I have e-mailed Dev directly over the past few weeks, but I get no response back from him so I am posting here in hopes of some help..
Abysmal
Abysmal
www.mikronauts.com - a new blog about microcontrollers
JMH
k.
