Newbie question about EEPROM usage for 12,000 data points on a "rolling average"
ElectricAye
I'm only vaguely familiar with how EEPROMs are used so forgive me if this sounds like an idiotic question:
I have 3 instruments taking measurements every 1 second, each measurement storing a LONG's worth of data. I would like to establish what I call a "rolling average" of the data coming from each sensor. By "rolling average" I mean I would like the Prop to look through the past 60 minutes worth of data and give me a separate one-hour average for each of the 3 instruments. This rolling average could be displayed every 5-10 minutes or so but it's important that, as new data enters the one hour "averaging window", the data older than 60 minutes is dumped overboard so it no longer is part of the average. This approach would require me to keep every data point of the past hour stored somewhere, so it seems logical to me to use an EEPROM. I estimated the following:
(3 instruments)*(1 data point every second)*(3600 seconds/hour) = 10800 data points/hour.
I suppose that would use up about 45 kbytes of EEPROM space??? But I thought I would allocate various regions of the EEPROM's address to store data only for instrument 1, instrument 2, etc. so I could easily keep track of what is stored where. And that would use more EEPROM space.
My first question: is this a sane way to use an EEPROM?
Second question: any idea how long it would take for the Prop to read and scan through about 11,000 data points to generate such averages? I need the Prop to generate this only about 10 times per hour while doing other tasks, so if it takes 10 seconds or so, it's no big deal. But if it's the sort of operation that would likely take minutes, then I will be despondent.
thanks for your insights,
Mark
Mark
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
You'll be remembering one measurement per second, retaining an hour's worth, or 3600 data.· Each datum occupies a long, or four bytes, so you'll need 14,400 bytes for each instrument, for a total of 43,200 bytes.· That's reasonable for an EEPROM.
You'll need to maintain, for each instrument, a table in EEPROM and a pointer to the current location in the table.· Each time you have a datum to record, you write it in the EEPROM at the location specified by the pointer, and then you update the pointer (add 4)·to point to the next EEPROM location.· When you reach the end of the table, you set the pointer back to the beginning.· In this way the table will always contain the last hour's data.
You speak of reading the whole table each time you want to calculate a one-hour average.· That is unnecessary.· You can calculate a rolling average more easily if you maintain the current sum of the 3600 readings for the last hour.· The rolling average will be this sum divided by 3600.
The key thing to notice is that you don't need to add up 3600 values each time you need that sum.· Instead, each time you're going to write a new value into the table, you first read the value currently in that location (which is one hour old), and subtract it from what I guess we can call the rolling sum.· Then you write the new measurement into the EEPROM (replacing the one-hour-old value), and add it to the rolling sum.
That way, each time you have a new measurement, you do one read, one subtractiion, one write, and one addition, to maintain the rolling sum.· That's way faster than reading and adding 3600 values to get the rolling sum, even if you divide by 3600 every time.
You ought to be able to do that process (including the division by 3600, which is the hardest part but not so hard at that) once per second for each of three instruments, and have lots of spare processing power.
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 4/13/2009 4:28:46 PM GMT
AWESOME!
Thanks!
Mark
What you do is maintain a single smoothed value.· Each time you get a new datum, you:
· (1)· Multiply the current smoothed value by some number n, say 1000
· (2)· Add the new value
· (3)· Divide the sum by n+1, say 1001, to get the new smoothed value.
This assigns constantly diminishing weight to old values.· The smaller n is, the faster the smoothed value changes (that is, the less it is damped).
And you don't store old values at all, and don't need the EEPROM.
That is an interesting method. Does it have a name ?
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
A disadvantage of the one-hour average, shared also by my simple smoothing method as described above, is that it takes some time for either method to settle on a reasonably accurate value.
This disadvantage can be eliminated by a refinement of my smoothing method.· Instead of setting n as a hard parameter, instead set a maximum value nmax.· Start out with n = 0, and increase it by 1 (up to nmax) after processing each incoming datum.·
After the first measurement m1, the smoothed value is simply m1 because you multiplied by 0, added m1, and divided by 1.· Then you increment n which now becomes 1.
After the second measurement m2 the smoothed value will be (m1+m2)/2.
After the third measurement m3, the smoother value will be (2((m1+m2)/2)+m3)/3.
And so forth.· The oldest values drop out gradually (instead of suddenly after an hour).
I haven't seen this described anywhere, but I'm sure others must have thought of it before I did.· I invented it when I was doing computerized temperature control (with an IBM 1800) in glass bottle plants in the early 1970s.
By setting nmax in response, say, to button-pushes, you can change the damping on the fly.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
http://www.itl.nist.gov/div898/handbook/pmc/section4/pmc43.htm
But how to turn that jargon in to real code, that I can not do.
But apparently you are suppose to divide by one digit higher, who would you divide by 65 by not using mulp/div?
This would NOT be correct: s =(s <<6 + x )>>6
As it would divide by 64 and not 65
Post Edited (tonyp12) : 4/13/2009 7:32:41 PM GMT
if you want to use 100 as n_max
i=0
s=0
loop
x= current input value
s=(s*i+x)/(i+1)
if i<100 then i=i+1
print 'current temp:' x
print 'average:' s
wait 1 second
next
Post Edited (tonyp12) : 4/13/2009 8:01:38 PM GMT
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
declare nmax float bit(16) initial(1000);·················· ·/* maximum value of smoothing constant n */
declare n float bit(16) initial(0);························· ··· /*·smoothing constant starts as 0··*/
declare average float bit(32) initial(0);···················· /* the floating average··*/
declare datum float bit (32);································· /* the measured instantaneous value goes here */
process_datum:··procedure;·································· /* we do it in a subroutine */
··· average ::= average * n;································ · /* multiply floating average by n· */
··· average ::= average + datum;························· · /* add the new datum (new measurement) */
··· average ::= average / (n+1);························ ··· /*· divide by n+1 to get new average */
··· n ::= n+1.0;···················································/* add 1 to n */
··· if ((n = nmax) or (n < nmax)) then return;··········· /* return if n not over limit nmax */
····n ::= nmax;········ ········································· /* else set n back to its limit */
··· return;························································· /* and that's it */
end process_datum;
I chose XPL because surely everyone can read and understand it.·
Note that, although n and nmax are going to be integer values, I declare them as floating point because they will be used in floating point calculations, and it's expensive to convert them every time they're used.· If all arithmetic is done in fixed point, then n and nmax should be fixed too.
Also, I initialize average to zero, even though the initial value doesn't affect the result.· Initializing it eliminates the risk of an early overflow or of an accidentally negative result.· In a Prop this is unnecessary because variables are initialized to zero at startup anyway.
Post Edited (Carl Hayes) : 4/13/2009 8:31:26 PM GMT
I'm storing all the data on an SD card, which will eventually add up to weeks if not months worth of data (SD cards will periodically get swapped out). But to give me a sanity check on the instruments and an "at a glance" feature on my VGA display, I wanted some sort of method for comparing present outputs with outputs seen over the past hour or so. The selection of an hour is totally arbitrary. It might even be nice to have daily and weekly rolling averages, too, so this fancy filtering system that y'all have been discussing might work for that too (?). That would be great, if it does.
Wow, I never thought asking such a simple question would cause me to learn so much!
Thanks to everyone for your erudite answers and sagacious suggestions!
Mark
http://forums.parallax.com/showthread.php?p=759589
Carl Hayes,
I tried your method against method 1 and 2 in the linked thread, and they are very close.
Beau Schwabe
IC Layout Engineer
Phil,
I know I originally stated that I would need to store a LONG on each datum, but on second thought it looks like the max number of pulses would be 500,000 so the "running sum" would not exceed:
(500,000 pulses per second) * (3600 seconds per hour) = 1800000000 which could be represented by a 32 bit LONG, I think.
So would I still need two LONGs to get accuracy??? or is there some other issue here that I'm totally missing?
thanks so much for helping me out!
Mark
And thanks to everyone who's contributed to this thread. Reading through this today and pondering all that you've said has not only solved my problems but it's also given me a nerdy high.
I love it!
Mark
