waitcnt asm — Parallax Forums
waitcnt asm
TomSTomS Posts: 128
edited 2009-04-12 18:13 in Propeller 1
I'm having a problem with waitcnt in assembly that I can't figure out. The loop repeats in about 20 seconds no matter what I assign to LoopTime. The "transmit" code seems to work fine and was taken from FullDuplexSerial and extensively modified.
Here's my code:
{{Serial_tx_asm.spin
Tom Smuts
VAR
  long cog
  long  tx_pin                  '6 contiguous longs (Don't change order or add/delete var's)
  long  desc_ptr
  long  ip_ptr
  long  dbm_ptr
  long  pcent_ptr
  long  bit_ticks
PUB Start(txpin, descPntr, ipPntr, dBmPntr, pcentPntr, baudrate) : okay
  stop
  longmove(@tx_pin, @txpin, 5)          'Fill var's from passed parms
  bit_ticks := clkfreq / baudrate       'bit_ticks = num clks per bit
  okay := cog := cognew(@entry, @tx_pin) + 1
PUB Stop
  if cog
    cogstop(cog~ - 1)
DAT
entry           org     0
                mov     t1,             par                 'get structure address
                rdlong  t2,             t1                  'get tx_pin
                mov     txmask,         #1
                shl     txmask,         t2                  'txmask defines transmit pin
                add     t1,             #4                  'get desc_ptr
                rdlong  descptr,        t1
                add     t1,             #4                  'get ip_ptr
                rdlong  ipptr,          t1
                add     t1,             #4                  'get dbm_ptr
                rdlong  dbmptr,        t1
                add     t1,             #4                  'get pcent_ptr
                rdlong  pcentptr,       t1
                add     t1,             #4                  'get bit_ticks
                rdlong  bitticks,       t1
                mov     rxtxmode,       #0                  'mode = 0
                test    rxtxmode,       #%100       wz      'init tx pin according to mode
                test    rxtxmode,       #%010       wc
                or      outa,           txmask
                or      dira,           txmask
loop_start
'Line 1
                mov     bytecntr,       descptr
                call    #transmit
                mov     bytecntr,       ipptr
                call    #transmit
'wait
                mov     time,           cnt
                add     time,           LoopTime
                waitcnt time,           LoopTime
                jmp     #loop_start
transmit        rdbyte  txdata,         bytecntr            'get 1st byte
                cmp     txdata,         #0          wz      'check for end of string
  if_z          jmp     transmit_ret                        'exit when end of string reached
                'ready byte to transmit
                or      txdata,         #$100
                shl     txdata,         #2                  ' 2 stop bits
                or      txdata,         #1
                mov     txbits,         #11                 ' 11 total bits
                mov     txcnt,          cnt
:bit            shr     txdata,         #1          wc      'output bit on tx pin
                muxc    outa,           txmask
                add     txcnt,          bitticks            'ready next cnt
:wait           mov     t1,             txcnt              'check if bit transmit period done
                sub     t1,             cnt
                cmps    t1,             #0          wc
  if_nc         jmp     #:wait
                djnz    txbits,         #:bit               'another bit to transmit?
                add     bytecntr,       #1                  'next byte in string
                jmp     #transmit
transmit_ret    ret
######################################## Undefined data ####################################
}                                                           ' temp variables
t1              res     1
t2              res     1
t3              res     1
descptr         res     1
ipptr           res     1
dbmptr          res     1
pcentptr        res     1
bitticks        res     1
bytecntr        res     1
rxtxmode        res     1
txmask          res     1
txbuff          res     1
txdata          res     1
txbits          res     1
txcnt           res     1
time            res     1
######################################### Defined data #####################################
LoopTime        Long    2_000
line1a          Byte "test string 1", 0
Tom
  • TreeLabTreeLab Posts: 138
    edited 2009-04-12 14:39
    I am not sure about the waitcnt, but in the transmit:wait code you are comparing cnt-t1 to zero using a signed compare. I think that this causes problems when the cnt rolls over at 2^32. Also, cnt is unsigned always.
    Cheers!
    Paul Rowntree
  • TomSTomS Posts: 128
    edited 2009-04-12 15:07
    Paul,
    That portion of the code is direct from FullDuplexSerial so I don't think that's the problem. Thanks all the same.
    Tom
    edited 2009-04-12 16:32
    The problem is that you've got LoopTime defined after a bunch of RESes (which, in this case, gives it whatever value is assigned to t1). Always put all of your RESes last so they don't overlap with subsequent definitions.
    edited 2009-04-12 16:51
    That did it.
    Tom
  • Chris_DChris_D Posts: 305
    edited 2009-04-12 17:07
    Paul,
    I believe you are incorrect on CNT always being unsigned.· In my experiments here, CNT is signed running from -max to +max.
    Chris
    CNT produces a 32-bit long. Whether or not it's "signed" depends entirely upon how its interpreted. Spin always interprets longs as 32-bit signed twos-complement integers. When writing in assembly, however, you can interpret them however you want: signed or unsigned. But that interpretation has nothing to do with the source (CNT or otherwise) from whence a long originates.
