@Bean: SXB 2.0 bug when using FUNC with local variables
@Bean,
This program
generates errors "Symbol <__PARAM0> not defined"
(__param0 is not used by SXB)
But note that the lines
lword = wordFunc lbyte,lbyte
do not generate an error but they should as the function expects only 1 byte argument!
Change the line to
and you get the error "Invalid number of parameters"
I used compiler version r19.
The program is also attached.
Edit: compiler version r14 compiles without error when using lines
(but then of course the FUNC 1,5,5,byte,byte,word,word no longer works
as that was fixed in a later release).
All later releases generate the errors.
regards peter
Post Edited (Peter Verkaik) : 4/10/2009 3:51:01 PM GMT
This program
' ========================================================================= ' File...... Memory_demo2.SXB ' Compiler.. SXB 2.00.16 ' Purpose... Optimizing memory use ' Author.... Peter Verkaik ' E-mail.... [url=mailto:verkaik6@zonnet.nl]verkaik6@zonnet.nl[/url] ' Started... 10 april, 2009 ' Updated... ' ========================================================================= '****************************************************************************** 'device settings '****************************************************************************** device SX28,OSCHS2 freq 20_000_000 id "Memory" stack 16 '****************************************************************************** 'CON section '****************************************************************************** '****************************************************************************** 'I/O pins '****************************************************************************** '****************************************************************************** 'VAR section '****************************************************************************** bytevar var byte wordvar var word longvar var byte (4) '****************************************************************************** INTERRUPTRATE con 230400 INTERRUPT nocode INTERRUPTRATE returnint '****************************************************************************** 'SUB/FUNC/TASK declarations '****************************************************************************** byteFunc FUNC 1,1 wordFunc FUNC 2,1 longFunc FUNC 4,1 '****************************************************************************** 'Reset entry '****************************************************************************** PROGRAM Start '****************************************************************************** 'Program Code '****************************************************************************** Start: Main: GOTO Main '****************************************************************************** 'Sub/Func/Task code '****************************************************************************** FUNC byteFunc 'returns byte lbyte var byte lword var word lbyte = __param1 lword = wordFunc lbyte ,lbyte return lword_msb ENDFUNC FUNC wordFunc 'returns word lbyte var byte lword var word lbyte = __param1 lword = wordFunc lbyte,lbyte return lword return ENDFUNC FUNC longFunc 'returns long lbyte var byte lword var word lbyte = __param1 lword = wordFunc lbyte,lbyte lword * lbyte 'result in __param1,__param2,__param3,__param4 return ENDFUNC 'end of file Memory_demo2.SXB
Change the line to
regards peter
That is the exact same error as I was getting with my earlier post. __param0 was being generated by compiler when I was attempting to use local variables.
RS_Jim
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Peter, there is a couple problem with the posted program.
1) The wordFunc is defined as having 1 parameter, but you are giving it two (this was not picked up because of the bug).
2) The wordFunc is unconditionally recursive. (Infinate loop)
Bean.
The fix appears to work.
To reply at your replies:
1) I added the 2nd argument to show the __param0 bug AND the bug that
2 arguments was not detected.
2) I was busy creatiig FUNC's (using copy and paste) when I encountered
the error. The program as such does not do anything useful.
regards peter
