SD Adapter
What is·Everyone's Favorite SD card adapter for the prop?
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
START:·
>Saving Data. . . .
>Signing OFF
containers the necessary pull-up resistors. It comes presoldered with a header that can plug into a solderless breadboard or a 6 pin female header.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
·I have purchased 4 boards from him and they are all sweet. I use the t.v. controller and the s.d. card for hours everyday for about a year now with no probs.
I use a 1gb Kinston sd card I just grabbed from the store. Format at fat in window xp and everything flys.
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Currently, I use a SD socket I salvaged from a dead SD card reader soldered to a pref board. It shares signal lines with a
keyboard and mouse connector on the back I cut from a dead computer MOBO. There is also a pair of wires to connect to
one of those yellow video cables for NTSC video (forgot the name at the moment) and the required resistors.
For the SD card, I use anything laying around, like 1GB KDATA, 32 MB generic brand, 2 GB Kingston, and a ton of others. Everything
works, even without pull up resistors.
Edit: Added a pic.
Post Edited (kevin101) : 4/10/2009 1:50:36 AM GMT
