Recursion — Parallax Forums
Recursion
KyeKye Posts: 2,200
edited 2009-04-10 09:22 in Propeller 1
Can the propeller chip do this? I mean it has a stack, so...
I'm thinking not from hints I've gathered but does anyone have the definitive word.
Nyamekye,
  • MagIO2MagIO2 Posts: 2,243
    edited 2009-04-09 19:35
    Of course ... if you have stack than you can have recursion. But the number of recursive calls is limited by the stack size - which is -as you know- very limited especially when your program gets bigger.
    And to be honest, I'd never use recursion on a limited system like the propeller. You can always change recursive code to be iterative.
  • rokickirokicki Posts: 1,000
    edited 2009-04-09 19:46
    Femtobasic uses recursion in its expression parser.
  • KyeKye Posts: 2,200
    edited 2009-04-09 23:18
    Okay, I just wanted to know, thanks.
    Nyamekye,
  • scottascotta Posts: 168
    edited 2009-04-10 04:36
    Kye,
    I've used it a few times, the Spin interpreter gets it correct as always but the
    stack limits your function recursion level.
    Scott
  • virtuPICvirtuPIC Posts: 193
    Kye,
    the propeller does not provide a hardware stack. We have a very RISCy machine. For recursion in assembler you have to implement it in software. Recursion in compiled code depends on the compiler - does it implement the stack or not? (Yes, I'm told that the C-compiler does.) Recursion in interpreted code depends on the interpreter. Here you need an explicit stack data structure anyway. Yes, SPIN provides it.
    Airspace V - international hangar flying!
    www.airspace-v.com/ggadgets for tools & toys
