New Product: Easy Bluetooth Module
Jen J.
The Easy Bluetooth Serial Module is an effective and low-cost solution to free your hardware applications from wires. The module is small in size, and with it's SIP header design, it can fit on any 0.1" spacing breadboards for rapid prototyping. The module can be powered voltages higher than 3.3 VDC since it has an on-board regulator; allowing it to be used with all the Parallax, Inc microcontrollers. The RBT-001 module is removable, so various other applications can be designed without the SIP header attached if desired.
The Easy Bluetooth module retails for $69.99
Post Edited (Jen J. (Parallax Inc.)) : 4/9/2009 11:53:13 PM GMT
