Current consuption problem, in Sleep Mode
Hi, I measured the current through Vdd pin,·of SX-28 during Sleep mode and it was two high! About 2 mA, it should be around 10 uA. The microcontroller didn't have any load, even with watch dog disable. I was using the port-b for wake-up.
Could someone giveme any advice?
Thanks!
Thanks!
Many times this is caused by floating input pins. Any pin that is an input (the default at power up) should be connected to Vdd or Vss via a resistor. Or you can use the built-in pull-ups.
Floating inputs can toggle back and forth very quickly causing excess current.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
