Making wireless print server.
As the title says, i'm interested in turning a propeller protoboard and an hb500 into a wireless print server.· can it be done?· i don't want to do any postprocessing or anything like that, all i want to do is reroute the usb driver to the bluetooth, and then relay whatever signal it is getting to the usb printer.· This is more of a personal challenge than a necessary project, since these kind of devices exist in retail.· But since i already have all the hardware that i would need, i'd like to see if it can be done this way instead of spending 150$ on a similar commercial device.· Look forward to any suggestions as of where to start.· Maybe a wrapper of some sort·programmed in vb or c#?· Let me know what you guys think!
Russ
Russ
Russell
Wireless printer for $75.00 dollars full color its even a full scanner copier. It just takes the wind out of my sails when I think about design , cost, time spent. LOL I have used the Eb500 card for just about everything else though its a very nice card. and has a very decent range another idea is PC's are so dirt cheap I picked up a few Dell optiplex 400 machines loaded for 50 bucks you could just stick a wireless card into on of those and off you go, however if its a learning experiance I would have no doubt the prop could do it
Post Edited (mikediv) : 4/9/2009 4:30:33 PM GMT
Russ
But how to config the prop to store and send on all the print data.
Russ psost your thoughts this is a very cool idea from a learning stand point
