Propeller Control Board #28205 Need Help ASAP!!
I currently have a Propeller Control Board #28205. I also have a hitachi h48c tri axis accelerometer. I am mounting it on an underwater robot. When the accelerometer reads tilt, I want it to activate a little propeller to adjust it to its rightful position. The problem is that for all the object codes, It seems that they are not made for this little red board that I have. I also cannot read what the accelerometer is reading. I am just so confused. I purchased this board for its ease of use with the accelerometer but that has been proven false. If anyone could help me it would be most appreciated.
Could you please attach your code to a posting.
For a VGA-Output you need several DA-converters build by resistors.
As the AUX-PINS have 10k resistors in series it's almost impossible to create a VGA-output with this board
To get an Output you have to modify the H48C-VGA-Demo that it uses the serial connection on PIN 31,30
@Parallax:
What I write here is meant as a constructive critic:
This is a professional board manufactured by Parallax itself.
I think your engineers have tested the board with some democode adjusted to THIS BOARD
for ALL SENSORS: H48C, HM55B, MOS-Fetdriver, GPS, Tachometer, Servos
What is the reason that these demofiles can't be downloaded from the product-page ?
From a real good customer-service I expect
demofiles that you can download in the propeller and have a quick test !
Download code
plug sensor
and PLAY
(not pray that the general object will fit the specialties of a certain board)
best regards
Stefan
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Post Edited (Tom C) : 4/9/2009 1:19:22 AM GMT
OK put the two ideas together:
how about REALLY WELL documentated hardware (the board) and REALLY WELL documented sensors
that it gets easy to develop the software ?
In my former job I had to deal with a lot of bad documented hard- and software.
Sometimes it took several days to get it running because I had to find out how things work by trial and error
The main buisseness in this job was NOT to become a specialist about a certain hard- or software.
The main buisseness was to develop a completed automated system to fulfill all the requirements of the customer.
If I have to decide which products to buy, I prefer WELL documented ones,
that makes it easy to maintain WITHOUT a 8 week trial and error phase until you are able to build all bought components yourself.
best regards
Stefan
as you have this board now and want to go on right now you can change the code of the H48C-democode
from VGA-output to serial-output over PIN 31,30 which is possible with the conrollerboard you have.
This means you have to replace the object "vga_text" with the object "Extended_FDSerial"
As MagIO mentioned you learn most from adapting the code. Make a start about changing the H48C-VGA-demo-code
and whereever there comes up a question feel free to ask it here in the forum.
I finish this post right here because I would like to see you to show us where your first question comes up
The question can be simple as can be but I would like that you are asking it.
Otherwise I have to guess around where your skill level is
If I guess too high my explanation is hard to understand
If I guess too low my explanation is boring and a waste of time
best regards
Stefan
