odd PWMPAL behavior
I've noticed an odd behavior with the PWMPAL sitting under my BS2sx. In my application I have each of the four PWMPAL output channels driving the gate of a MOSFET to turn on a high-power LED. I do have a 220 ohm resistor in between each PWMPAL output and its MOSFET gate. In my software I turn on or off all four channels together by setting (in a small loop) each channel to the same on/off times, specifically 50 msec on and 450 msec off. So all four channels should be pulsing at 2 Hz with 10% on-time, with perhaps a very slight skew between channels, since I have to set them one at a time. The BS2sx is talking to the PWMPAL's serial I/O pin at 38400 baud.
What I actually see sometimes (about half the time I power up the system) is that one of the four channels, I don't know which one, runs at a different rate than the other three. Sometimes the difference is barely noticeable until a couple of minutes pass, and sometimes it's obvious very soon. It's like either (a) one channel's clock is running at a different rate than the others' clocks, or (b) that channel's on-time and off-time registers got loaded with a different value.
I doubt (a) is the cause, assuming all four channels share a clock; I don't know if that's the case. Cause (b) could occur if bit errors occur on the serial input when loading the registers, so that the channels don't end up with the same on and off times.
Does anybody have any experience with odd PWMPAL behavior? I can think of only two possible remedies: (1) drop the serial baud rate to 19200 or 9600 to reduce the possibility of serial errors; (2) swap out the PWMPAL with a spare.
Parallax Engineering
What do you mean by "unstable"? I know there will be some frequencies and duty cycles that can't be precisely achieved, but any that can be should be stable (i.e. not changing with time). There's nothing that I can see in the PWMPAL documentation that implies that there are "unstable" frequencies or duty cycles.
Okay, if you look at the code snippet above, you see I load the on-time registers with 40 * 50 or 2000. 2000 * 25 usec = 50000 usec = 50 msec. Exactly. The off-time is 40 * 450 or 18000. 18000 * 25 usec = 450000 usec = 450 msec. Exactly. Total period is 500 msec -> 2 Hz. Duty cycle is 50 msec / ( 50 + 450 ) msec = 0.1 = 10%. Exactly.
So what's so unstable (or unreachable) about 2 Hz at 10% duty cycle? And why does it affect only one channel? The other three are in precise (to the eye) lock step.
Post Edited (TWRackers) : 4/9/2009 11:49:41 PM GMT
The PWMPAL seems to want the starting phases of the four channels to be set explicitly, hence the "SP" command.
Regardless of how exact your calculations are there are only so many clock cycles available to process each channel. Any number of factors can affect the timing for that channel including settings for other channels, which is partly why all duty cycle ranges are not available for all frequencies. When serial commands are sent the signal is also briefly interrupted. The reason I asked for complete code is that I cannot put what you posted into the editor and run it. So in that sense it is incomplete. With the code I would have been able to evaluate what the code wanted versus the results. It seems you have found your answer though so I will consider this issue solved. Take care.
What I saw that surprised me was that the LEDs flickered during the fraction of a second that the Stamp was redisplaying the prompt. I thought the outputs of the PWMPAL were supposed to operate independently of whatever the Stamp was doing, as long as the Stamp wasn't talking to the PWMPAL or changing any of the pins the two devices share.
I'm attaching the code which I was running.
You can optimize your code considerably…for example, for each case you print:
DEBUG CLREOL, " selected... "
This occurs for every line…instead you should print it immediately following the DEBUGIN statement so you can remove so many instances of it. As for your flicker problem….I can’t see where the menu gets re-displayed…it seems like the cursor just moves back to the original position. If this is the case, then the outputs would have only been affected by having just set them, unless I am not understanding what you mean.
You are correct, most of the text is not re-displayed upon each pass. I wrote that test code weeks ago, so I hadn't looked closely at it since then. Now that I do look at it, what I may be seeing is flickering caused by the channels being reconfigured while they're still running. What I will do is turn off the outputs before I reconfigure them, then turn them back on.
' the output certain notes stutter (double) AT TIMES but not always.
' At an octave higher the problem is gone.
' {$STAMP BS2}
SEROUT 0,6,[noparse][[/noparse]"!PWMSS",240]
x VAR Nib:y VAR Nib:c VAR Byte:n VAR Nib:z VAR Byte
dt VAR Word:d1 VAR Byte:d2 VAR Byte
play
FOR x=0 TO 3:FOR y=0 TO 3
LOOKUP x,[noparse][[/noparse]20,24,18,27],c:LOOKUP y,[noparse][[/noparse]2,4,3,4],n
dt=14544/(c*n):d1=dt//256:d2=dt/256 ' change 14544 to 7272 to raise octave
SEROUT 0,6,[noparse][[/noparse]"!PWMM1",d1,d2,d1,d2] ' play note listen to PWMPAL channel 1
PAUSE 300
NEXT:NEXT:GOTO play
That's the whole point of the device.
AND for some reason at higher frequencies it doesn't.
I'm only using squarewaves, so it's not the unusable freq/dutycycle.
At one time I thought I had it fixed by proper settings on the 'status bytes',
but ????
>would momentarily disrupt the outputs.
Then you'd be blowing mosfets like a bad dog trying to do
something like a H bridge [noparse]:([/noparse]
(all devices off) elst the dreaded short between rails
