control plus power over 2 wires
Have a project I have been thinking about and wonder if there is a chip out there already that can do what I need it to.· I do know that the stamp would work for this, but I would need·7 stamps for a very simple project and it would get a little spendy. (6 for motors, 1 for controller)
Here is what I am trying to do...
I have a 2 conductor sheilded wire that uses an 3pin XLR style connector.· (5v+ or 12v+, data, gnd)· I have 6 motors that are all spaced a ways apart and only connected via the 2 conductor wire.· I need to control the direction of each motor independantly (basically 2 relays by each motor, up or down, if no relay is active, then the motor is off).
Each motor does have 120 available for a local power supply, however size is a problem.· I am trying to fit the circuit I am building and the two relays in a box that is 2" x 2" x 4".
I would be ok using a stamp for the main controller, but just wondering if there is a simple way to control the two relays over one wire.· Actually it would be like 12 channels, 2 for each motor.
If you have any ideas of a circuit that does that or what I should be looking at please let me know.· I was looking at serial control to a basic stamp, but putting a stamp by each motor is kind of over-kill...
Thanks in advance...
Question - Does this use the I2COUT command?· The I2COUT command looks like it uses 2 wires?· Is there a different command I should be looking for?
Thanks!
If this is the command to use...
OWOUT 0, 5, [noparse][[/noparse]bitOne, bitTwo]
Then where do I put the ROM number that comes addressed to each chip? I see near the bottom of the syntax explaination it shows commands like Read ROM, Match ROM, Skip ROM, Search ROM. I understand what these do, I think, but I don't understand how to put them into the command to send out.
The way I understand this is that I send the chip ROM number (which according to the data sheet is stamped on the chip), followed by the two bits that I want to output to the two I/O pins on the chip. What am I missing here?
Thanks again for all the help!
