Rotate on Byte? Or always a long
TJHJ
Hey all,
Dumb question. If I use the rotate command on a byte, will it properly rotate around to the 8th bit? Or Does rotate like its a long?
Ex
Side note
Anyone have a good way to rotate a 4 bit value around? With out a bunch of checking?
Im really trying to rotate %1100 right 1 per loop. But keep it all in the 4 bit format.
·TJ
I owe everyone here a bunch, So thanks again for answering my dumb questions.
Projects. RG500 ECU system. PropCopter. Prop CanSat. Prop Paste Gun.
Suzuki RG500 in a RGV 250 frame.
Bimota V-Due (Running on the fuel injection system)
Aprilia RS250
Ex
Var byte RotateTest Pub Main RotateTest := %1010 RotateTest <-= 8 'Is rotate test now %0000_1010 or %1010_0000_0000 ???
Side note
·TJ
Aprilia RS250
To rotate a 4 bit value, you have to do masking and multiple shifts like
(value << 1 & %1110) | (value >> 3 & %0001)
rotate it then do if greater then 16 subtract 15 this will clear the greater bit and set lowest bit at same time
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
((value << 1) | (value >> 3)) & %1111
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
