Another Serial Question (again)
When i try to send "!aannttccffCR" CR is Cariage Return @ 9600bauds
I get !aannttcc then comes a betha ascii (FE in hexa)
But @ 115200 I get the good string...
I'm using extended_FDSerial
Shorter Strings are good int the two cases
What's wrong with that?
Laurent
Laurent
Secondly, are you closing the FDX after transmitting as you also need to ensure the characters have been sent first. Easy to check this one - use waitcnt(clkfreq/100+cnt)
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
it doesnt work at all...
Is there something else to change to upgrade the size of txbuffer?
