BASIC Stamp Editor - Access violation
Greetings!
This evening, when I closed the BASIC Stamp Editor, the following error occurred...
BASIC Stamp Editor
Access violation at address 004CE38C in module 'Stampw.exe'. Read of address 00000100.
OK··
Where·/ how should I report this?
Brian
BASIC Stamp Editor
OK··
Brian
Why would you think an "Access violation" in "Stampw.exe" didn't have something to do with the BASIC Stamp Editor?
Brian
Because I've gotten the same errors on other programs. My theory (and that's all that it is) is that windows is lightly corrupted, and the heap management isn't what it should be. I've reinstalled windows for another reason (COM port driver failure) and the IE problem went away.
While your theory may be true this particular message indicates, beyond any doubt, that this is a bug in BASIC Stamp Editor.
Brian
Microsoft wants you to think it is not their problem but it is a Windows operating system problem. Think about it. If there was a problem with the Stamp Editor wouldn't us thousands of users have the same problem? I have had problems with programs in the past and found totally un-related programs and hardware the real problem. Check your registry and possible malware for trouble spots.
Dave
Dave W.
It isn't. The address 004CE38C is in the code area of Stampw.exe.
That is specious reasoning.
It's a fresh installation of Windows. There's nothing else installed and all the updates have been applied.
Brian
"Access violation at address 004CE38C in module 'Stampw.exe'. Read of address 00000100."
It could be that the editor is trying to get to memory that it shouldn't, or that the OS thinks that memory is illegal to the editor when in fact that is not the case. The second scenario is what I meant by 'windows lightly corrupted.' Something between the time I installed windows and the time I closed ( in my case) IE changed in some system file, and so the error arrives.
But, like I said, it's all conjecture.
Please post your version number.· Not an expert, but it's something quick and easy to rule out.
I do. It was downloaded and installed two weeks ago.
Biran
If you have a Anti Virus or Registry Cleaner or something like that it can give you problem because I have had them my self with the Stamp Editor if you have them installed try· Stamp Editor· with these program turn off and
see if the same thing again
I hope this helps
··Thanks for any·
Sam
It's a fresh installation of Windows. Neither anti-virus nor Registry cleaner is installed.
Brian
