Crazy Inventions
I have been building and desinging electronics since I was in grade school and my dad bought me a 30 in 1 electronics kit. Since then I have made lots of cool things and a few that worked but were really crazy. So my question to everyone out there is:
What is the craziest invention you ever made.
For me it was the mouse zaper. The basic idea is that air has a break down voltage of 1000V/cm so I made a box 15 cm long and 5 cm wide and 5 cm tall. Chese was placed at the end of the box to attract the mouse(penut butter turned out to work just as good and much cheaper and does not go bad.) Electrodes were placed on each side of the box in the middle. I had an electronic circut called a Marx Generator whch created a 4000V high current power source.
It worked. When a mouse(or anything else that conducts electricity wider then 1cm like a finger) walked between the electrodes it was killed instantly. The problem was the generator would continue to zap the mouse every couple seconds after it built up enough power to jump the gap. The other problem was the current was more then enough to kill a human that stuck there finger into it(not that I ever tried).
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Pray tell: what was the principle behind this marvelous device's operation?
· -- Carl, nn5i@arrl.net
Leon
here is all you need to know to build the part that kills the mice:
http://en.wikipedia.org/wiki/Marx_generator
Shot pink golf balls and half the people watching could not even see them leave the barrel. Used folded paper towel as wadding and a stun gun for ignition.
WARNING i do not suggest you make one of these. I coated the whole guns outside in a very strong elastic Polymer that is used in blast resistance coatings and ballistic armour. This way if it failed from pressure no one got hurt.
Range was over 2miles, that is as far as i rode a dirt bike away from camp looking for the balls.
http://forums.parallax.com/showthread.php?p=536994
Parallax Engineering
A similarly-inclined engineer at Xerox Research (UK) Ltd developed the concept of an on-line shredder - a shredder on the output of a photocopier for disposing of secure documents so that no-one could see them after they were copied.
Leon
guess in the country you can let the mouse go away from houses. I could only let it go if I didn't like one of my neighbours.
my uncle has a really good mouse trap. barn cats
The army made 1000 of these and several thousand atomic shells. Someone quickly saw the absurdity and the mortars and shells were recalled from Germany. (Could you say this was a flash of brilliance)
Luckily, the atomic threat has moved on. (I would hate to have been blown away by this idea).
