RFID troubles
I purchased the reader and tag sampler, downloaded the sample code and have it running on a BS2.
The only tag the reader 'sees' is the white card, and that is only when I lay it on the reader.
I read that it is supposed to have a range of about 4". It will not pick up any of the other tags in the kit. Is this normal? What could I be doing wrong?
I have tried a different BS2, & checked the voltage.
When I type in the tag ID, of the white card, in the program it still reads it "unauthorized"
Any suggestions?
Mike2545
This message sent to you on 100% recycled electrons.
Any suggestions?
Mike2545
Mike2545
I have run 3 different program samples on two BS2's with the same results. [noparse]:([/noparse]
Mike2545
Post Edited (Mike2545) : 4/5/2009 2:17:48 AM GMT
Mike2545
The bridge you see in that photo is normal as those pads are connected together on the PCB. It does seem you have a problem related to the antenna portion though so you should definitely take Mike Green’s advice and call our Tech Support Dept.
Parallax Engineering
Post Edited (Chris Savage (Parallax)) : 4/6/2009 7:42:37 PM GMT
Mike2545
Mike2545
- Stephen
Pin 1 = Sout
Gnd = -
Vcc = +
Not too hard to connect.
Mike2545
I will try a different location.
Mike2545
Mike2545
I am now reading the keyfob at a full 4" and the White cards at 4.5".
Sorry to say I destroyed the Black World tag seeing if it had anything in it.
I just sent the first unit back to the tech department today. They will test it and find nothing wrong
Oh well live and learn....
Mike2545
Mike2545
