Linx receiver question
wmtell1
Can I have the Linx receivr pause for a signal for a small time and then the go to another part of my code?
William
William
Are you asking if you can wait for a defined timeframe for a specific signal on the DATA line? The Timeout and·Tlabel variables are options in the SERIN command that can be used to wait for a defined timeframe for any signal. Timeout triggers on any serial data and defines the wait time; Tlabel specifices the program direction if the wait time is exceeded. Add an error trapping routine if you utilize Timeout and·Tlabel· and need to wait for a specific signal.
As an alternative, consider using the WAIT qualifier to wait for a specified dataset prior to receiving additional data. Please view the SERIN Function in the Help file for more information.
························ Craig Eid
··········· Triad Research and Development
Electical Engineering Design and Consulting Services
··················· www.TriadRD.com
William
Does anyone know the longest range that I can get from the Linx receiver?
Thanks for all the helpp!
William
