Usb or serial
map maker
I am just getting into microprocessors with no experience at all.
But im dieing to start building my own simple components.
I am looking at starting with the discovery kit but can only get the Usb style from my local shop.
I want the serial type because i think it will be simplier.
My computer only has usb but im able to borrow my work computer and my pda has serial.
Would it better to spend a little more to get the serial or would i be better off getting the usb?
If anyone has any comments, i would appreciate it.
Dan
Dan
It's much more important to find out what you're assuming or believing than our various opinions.
You will get different opinions from different people and they are (of course) all correct.
Do not be concerned about communicating with a microcontroller through the USB interface, as there are numerous tools available that allow you to seamlessly convert from Serial (RS-232) to USB. The Parallax BASIC Stamp development system supports USB through a virtual·Com port·and·PBasic·does not distinguish a difference between USB and Serial (RS-232).
Connecting a USB port to your computer requires·the installation of the appropriate drivers and a·USB to Serial (RS-232) adapter that is compatible with the Parallax development system. Parallax offers a few options based on the FTDI chipset -http://www.parallax.com/Store/Accessories/Tools/tabid/162/CategoryID/37/List/0/Level/a/ProductID/32/Default.aspx?SortField=ProductName%2cProductName·and http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/usb/List/0/SortField/4/ProductID/378/Default.aspx· .
Please·view the following link for more information on USB to Serial (RS-232) adapter cables - http://forums.parallax.com/showthread.php?p=784398·.
························ Craig Eid
··········· Triad Research and Development
Electical Engineering Design and Consulting Services
··················· www.TriadRD.com
Once you have a direction / application than buy appropriate processor hardware.
A “universal” kit is just like Swiss army knife with 100+ attachments – relatively spendy if all you want is a big blade and a can opener.
Read a good general book on microprocessors, come up with application and than come back to forum and seek further advice from the group.
Cheers
I have never used anything but USB.·I have many USB to serial adapters. (Parallax sells them with the name "USB2SER.") I have had as many as five Stamps connected through five USB2SER adapters to a USB hub connected to my laptop.
Everything has always worked very well. I am also a newbie.
Have fun!
--Bill
You are what you write.
I think ill go with the usb.
I would love to read a book but i am just bursting at the seams to get building.
My idea is to have a module out in the woods that would be able to go in sleep mode. Then have 2 pir sensors that would detect when a deer walks by. It would date stamp the movement showing me direction. Then go back to sleep. I would also like to add tempurate and other sensors to see if i can find some corelation to deer movement to natural cycles.
I am thinking the parallax discovery series kit will be able to·show me these basics.
From there i would ike to add on to build this module.
If there is a better way, i'm all ears.
Thanks for your opinions, and i look forward to seeing others projects.
Dan
http://forums.parallax.com/showthread.php?p=775638
