Basic Stamp PCB
I am designing a Printed Circuit Board for my Clock Project. Does the BS2 P40 have an on board Voltage Regulator on the stamp itself? or do I need to add one to the PCB? Should I connect the VCC to the VIN pin? Any other ideas or concerns that I should keep in mind? In addition I would like to add a D Sub connector to the PCB in case I need to update the code, how do I do this?
They say if you Play a Microsoft CD backwards you can hear satanic messages, that's nothing because if you play it forward it installs Vista!
I didn't Fail 10,000 times, I simply found 10,000 ways that didn't work. -Thomas Edison
There's a diagram in the Stamp Basic Manual showing how to connect a DB9 connector for programming. I think it's on page 28. There's also a diagram on the BS2p40's schematic downloadable from the webstore page for the BS2p40.
The regulator is an LT1121. This is rated for a maximum current of 150mA, but practically is limited by power dissipation. The closer Vin is to 5.5V, the less heat will be dissipated for a given amount of current. The Stamp itself takes about 40mA when running.
Post Edited (Mike Green) : 4/4/2009 4:56:54 AM GMT
