frequency calculation — Parallax Forums
trazymtrazym Posts: 10
edited 2009-04-03 17:37 in Propeller 1
Hi, i've bought a propeller education kit a week ago and i want to extract the period T of a discret signal.
_____---_____---_____
T?
Thank you for your answers
Fred
  • MagIO2MagIO2 Posts: 2,243
    edited 2009-04-03 12:04
    Well, that's a lot of information .... missing ;o)
    There are lot's of ways to do that. SPIN? PASM? Using WAITPEQ, WAITPNE or using counters ...
    How accurate does the result need to be? The most accurate would be to use the counters as hardware itself counts the pulse/pause time. Then you only need the code to read the values, calculate the overall T and reset the counters.
    What frequency do you expect?
  • trazymtrazym Posts: 10
    edited 2009-04-03 12:54
    "The most accurate would be to use the counters as hardware itself counts the pulse/pause time. Then you only need the code to read the values, calculate the overall T and reset the counters." -> That's exactly what i want to do but i need to transalte the idea into the program .SPIN !!
    "What frequency do you expect?" ->about 200Hz
    Thank you
  • TreeLabTreeLab Posts: 138
    edited 2009-04-03 14:21
    In my experience you can have a spin program monitoring a counter at up to 5 kHz without loosing an edge. If you just need to know how many pulses come by in a second, then a counter can be set up from SPIN, then have the cog wait for exactly one second, then wake up to read the counter. You need to decide what precision you need, which will set the time that you need to wait before reading the counter.
    The B counter is set up to read edges on Pin using
    dira[noparse][[/noparse] Pin ]~
    ctrb := %01010<<26+ Pin ' Counter B is looking at the Schmitt-conditioned opto signal (inverted)
    frqb := 1
    phsb := 0
    Cheers!
    Paul Rowntree
    So, one of the simple ways for one measurement is:
    pinMask|=Pin                    ' create the pin bitmask by giving the pin number (0-31)
    waitpne( pinMask, pinMask, 0)   ' we are in the middle of somwhere, so we have to wait until we found the start of a clock-cycle
    waitpeq( pinMask, pinMask, 0)   ' here we wait for the rising edge
    startPulse:=cnt                 ' store the counter value
    waitpne( pinMask, pinMask, 0)   ' here we wait for the falling edge
    startPause:=cnt                 ' if you want the pulse-pause ratio, you can store the counter here as well
    waitpeq( pinMask, pinMask, 0)   ' here we wait for the next rising edge
    t:=cnt-startPulse               ' now we can calculate t, pulse-pause ratio, frequency ...
    freq:=clkfreq/t
    Please note: this is really a simple implementation. There are a lot of ways to improve it and adapt it to your needs.
    E.G.:
    - This one blocks if no clock signal is attached to the pin. To avoid that, you have to implement your own waitpne/waitpeq.
    - It's only measuring one cycle. If you need continuous measurement then you have to put the stuff in a loop
    - For roundabout 200Hz this should be adequate enough, if you need it more adequate, you have to use counters.
