TCS230 Color Sensor and LEDs
Hello,
I am using a BS2e education board with a TCS230 color sensor.· I am also using a DB-Expander Daughterboard-to-SIP.· I am aiming to have the sensor not only read-in and scan through the eeprom to look for matches but to also activate external·red, green·and blue·LEDs.· I would like to have three LEDs hooked up to the sensors output (slot C on the daughterboard).· The aim is to have the sensor scan through the colors and once, for example red is matched, then this would turn on the red led.· If I then turn to another color and its match is found in the eeprom, this would turn on its representative LED.· I will using a total of three LEDs (red, blue and green).·
Eventually, the overall goal would be to have the external red, green, and blue LEDs vary in intensity based on the intensity of the representative colors which·are sensed.
Current Code for to read colors or references ratios (From Parallax):
'·· File...... TCS230DB_demo(DB-Expander).bs2
'·· Purpose... To extract color data from the TCS230-DB via the DB-Expander
'·· Author.... Parallax, Inc.
'·· E-mail.... support@parallax.com
'·· Started... 8 November 2007
'·· Updated...
'·· {$STAMP BS2e}
'·· {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' This program is used to get and output color data from the TCS230-DB
' color sensor daughterboard when connected to a BS2 via the DB-Expander.
[noparse][[/noparse] I/O Definitions ]
' Change the "BS2" pin designators as needed.
' Sig········ BS2·· DB-Expander
· OUT··· PIN·· 9··· '··· C
· LED··· PIN·· 10··· '··· D
· S2···· PIN·· 6··· '··· E
· S3···· PIN·· 5··· '··· F
[noparse][[/noparse] Constants ]
' Define count periods for each color. Adjust these for readings just under
' 255 for a white sheet of paper.
pRED···· CON·· 12···· 'Red reading period.
pGREEN·· CON··· 8···· 'Green reading period.
pBLUE··· CON··· 6···· 'Blue reading period.
[noparse][[/noparse] Variables ]
RED····· VAR·· Word·· 'Red color reading.
GREEN··· VAR·· Word·· 'Green color reading.
BLUE···· VAR·· Word·· 'Blue color reading.
[noparse][[/noparse] Initialization ]
· HIGH· LED·········· 'Turn on LED.
[noparse][[/noparse] Program Code ]
DO
· GOSUB· Color······· 'Get the color data, and output to DEBUG.
· DEBUG· "R", DEC3 RED
· DEBUG· " G", DEC3 GREEN
· DEBUG· " B", DEC3 BLUE
· DEBUG· CR
LOOP
[noparse][[/noparse] Subroutines ]
' Color: Read all three color components.
Color:
· LOW· S2·················· 'Address the red output.
· LOW· S3
· COUNT· OUT, pRED, RED···· 'Read the red component.
· HIGH· S3················· 'Address the blue output.
· COUNT· OUT, pBLUE, BLUE·· 'Read the blue component.
· HIGH· S2················· 'Address the green output.
· COUNT· OUT, pGREEN, GREEN 'Read the green component.
· RETURN
Code used to Scan and Look for matches (Color Me Tickled Code):
[noparse][[/noparse] Title ]
' Buildg A Spectrometer (Sample Code) - colorselect_1.BS2
' {$STAMP BS2e}
' {$PBASIC 2.5}
[noparse][[/noparse]Inializations]
TcsLeds·· PIN 10 ' LEDs enable - active low
TcsFreq·· PIN 9 ' freq from TCS230
TcsS2···· PIN 6 ' color filter control
TcsS3···· PIN 5
[noparse][[/noparse] Declarations ]
Red·········· CON 0 ' TCS230 filter selection
Green········ CON 1
Blue········· CON 2
Clear········ CON 3
ScanTime····· CON 10 ' scan time in millisecs
ScaleMax····· CON 255 ' max for scaled values
IsOn········· CON 0 ' LED control is active low
IsOff········ CON 1
NumColors···· CON 7 ' seven M&M colors
ColorThresh·· CON 4 ' allowable variance
TermChar····· CON 0 ' terminater for strings
StrLen······· CON 12 ' max length of names
filter··· VAR Nib ' filter selection
rawColor· VAR Word ' raw return from TCS230
calRed··· VAR Word ' red calibration
calGrn··· VAR Word ' green calibration
calBlu··· VAR Word ' blue calibration
redVal··· VAR Byte ' red value
grnVal··· VAR Byte ' green value
bluVal··· VAR Byte ' blue value
rgb······ VAR redVal ' colors array
inKey···· VAR Byte ' input from user
colIdx··· VAR Nib ' color index
rgbIdx··· VAR Nib ' rgb index
testVal·· VAR Byte ' test value
eePntr··· VAR Word ' data table pointer
char····· VAR inKey ' char to print
[noparse][[/noparse] EEPROM Data ]
' RGB data
Colors DATA 098, 064, 057 ' brown
DATA 127, 049, 054 ' red
DATA 161, 119, 084 ' orange
DATA 180, 193, 103 ' yellow
DATA 031, 089, 093 ' green
DATA 028, 068, 163 ' blue
DATA 052, 057, 124· ' violet
' Color Names
CN0 DATA "Brown", 0
CN1 DATA "Red", 0
CN2 DATA "Orange", 0
CN3 DATA "Yellow", 0
CN4 DATA "Green", 0
CN5 DATA "Blue", 0
CN6 DATA "Violet", 0
Setup:
TcsLeds = IsOff ' start off
OUTPUT TcSLeds ' allow direct control
GOSUB Calibrate_White ' white balance sensor
GOSUB Calibrate_Colors ' calibrate color table
Main:
DO
GOSUB Read_RGB ' scan color
DEBUG "RGB = ", ' display components
DEC3 redVal, ", ",
DEC3 grnVal, ", ",
DEC3 bluVal, " "
GOSUB Match_Color ' compare scan to table
IF (colIdx < NumColors) THEN ' match was found
GOSUB Print_Color
DEBUG CR
ELSE
DEBUG "No match", CR
ENDIF
PAUSE 1000 ' delay between scans
LOOP
END
' Calibrates "white" to ambient conditions
Calibrate_White:
DEBUG CLS, "TCS230 White Balance"
DEBUG CR, CR, "Insert white sample. Press a key to scan..."
DEBUGIN inKey
GOSUB White_Balance
DEBUG CR, CR, "White balance complete."
PAUSE 1000
DEBUG CLS
RETURN
' Reads "white" and calculates calibration values
White_Balance:
filter = Red
GOSUB Read_Color ' read raw red
calRed = ScaleMax * 256 / rawColor ' calculate red cal
filter = Green
GOSUB Read_Color ' read raw green
calGrn = ScaleMax * 256 / rawColor ' calculate green scale
filter = Blue
GOSUB Read_Color ' read raw blue
calBlu = ScaleMax * 256 / rawColor ' calculate blue scale
RETURN
' Calibrates color table to ambient conditions
Calibrate_Colors:
FOR colIdx = 0 TO (NumColors - 1) ' loop through all colors
DEBUG CLS, "TCS230 Color Calibration: "
GOSUB Print_Color
DEBUG CR, CR, "Insert sample. Press a key to scan..."
TcsLeds = IsOn ' light up scan area
DEBUGIN inKey
GOSUB Read_RGB ' scan sample item
eePntr = Colors + (3 * colIdx) ' point to table entry
WRITE eePntr, redVal, grnVal, bluVal ' save new data
NEXT
DEBUG CLS
RETURN
' Reads selected color from TCS230
' -- takes "filter" as input
' -- returns "rawColor" as output (unscaled color value)
Read_Color:
SELECT filter
CASE Red
LOW TcsS2
LOW TcsS3
CASE Green
HIGH TcsS2
HIGH TcsS3
CASE Blue
LOW TcsS2
HIGH TcsS3
CASE ELSE ' clear -- no filter
HIGH TcsS2
LOW TcsS3
ENDSELECT
TcsLeds = IsOn ' light sample
COUNT TcsFreq, ScanTime, rawColor ' return unscaled value
TcsLeds = IsOff
RETURN
' Reads and scales RGB colors
Read_RGB:
filter = Red
GOSUB Read_Color
redVal = rawColor */ calRed MAX ScaleMax
filter = Green
GOSUB Read_Color
grnVal = rawColor */ calGrn MAX ScaleMax
filter = Blue
GOSUB Read_Color
bluVal = rawColor */ calBlu MAX ScaleMax
RETURN
' Compares current color scan with known values in
' table. If match is found, the value of "colIdx"
' will be less than "NumColors"
Match_Color:
colIdx = 0
DO WHILE (colIdx < NumColors) ' check known colors
rgbIdx = 0
DO WHILE (rgbIdx < 3) ' compare rgb components
eePntr = Colors + (colIdx * 3) + rgbIdx ' point to color table
READ eePntr, testVal ' read known r, g or b
testVal = ABS(testVal - rgb(rgbIdx)) ' calculate variance
IF (testVal > ColorThresh) THEN EXIT ' if out-of-range, next
rgbIdx = rgbIdx + 1 ' test next component
LOOP
IF (rgbIdx = 3) THEN EXIT ' match found
colIdx = colIdx + 1 ' try next color
LOOP
RETURN
' Print color name
' -- takes "colIdx" as input
' -- allow this to fall through to Print_String
Print_Color:
LOOKUP colIdx, [noparse][[/noparse]CN0, CN1, CN2,
CN3, CN4, CN5, CN6], eePntr
' Print a string stored in DATA table
' -- point to first character with "eePntr"
Print_String:
DO
READ eePntr, char ' reach character
IF (char = TermChar) THEN EXIT ' end of string?
DEBUG char ' no -- print char
eePntr = eePntr + 1 ' point to next
LOOP
RETURN
I would really appreciate some help on this project.·
Thanks in advance,
steve
'·· Updated...
'·· {$STAMP BS2e}
'·· {$PBASIC 2.5}
DO
· DEBUG· CR
LOOP
Color:
· LOW· S3
· RETURN
' {$STAMP BS2e}
' {$PBASIC 2.5}
TcsS3···· PIN 5
Green········ CON 1
Blue········· CON 2
Clear········ CON 3
IsOff········ CON 1
' RGB data
' Color Names
CN0 DATA "Brown", 0
CN1 DATA "Red", 0
CN4 DATA "Green", 0
CN5 DATA "Blue", 0
Setup:
Main:
DO
DEC3 redVal, ", ",
DEC3 grnVal, ", ",
DEC3 bluVal, " "
GOSUB Print_Color
DEBUG CR
ELSE
ENDIF
LOOP
END
Calibrate_White:
DEBUGIN inKey
GOSUB White_Balance
PAUSE 1000
DEBUG CLS
RETURN
White_Balance:
filter = Red
filter = Green
filter = Blue
RETURN
Calibrate_Colors:
GOSUB Print_Color
DEBUGIN inKey
NEXT
DEBUG CLS
RETURN
Read_Color:
SELECT filter
CASE Red
LOW TcsS2
LOW TcsS3
CASE Green
HIGH TcsS2
HIGH TcsS3
CASE Blue
LOW TcsS2
HIGH TcsS3
HIGH TcsS2
LOW TcsS3
ENDSELECT
TcsLeds = IsOff
RETURN
Read_RGB:
filter = Red
GOSUB Read_Color
filter = Green
GOSUB Read_Color
filter = Blue
GOSUB Read_Color
RETURN
Match_Color:
colIdx = 0
rgbIdx = 0
LOOP
LOOP
RETURN
' Print color name
Print_Color:
Print_String:
DO
LOOP
RETURN
Thanks in advance,
steve
Parallax Engineering
steve
