String to ASCII — Parallax Forums
String to ASCII
KlapKlap Posts: 65
edited 2009-04-02 22:13 in Propeller 1
I was wondering if there was an easy way to convert ASCII text into its equivalent numerical form?
Here is the spin code I used to do it (also see attachment)
File: StringToASCII.spin
Programmer: Aaron Klapheck
Date: 31-Mar-09
Code that may need to be changed is bracketed by "***" and is located in
the CON section only. In the PUB init block the speaker code may be deleated
if a speaker is not being used.
Run this program by itself to test to see if it is working.
If calling this program as a subroutine (its primary use) then don't worry about
changing any of the code.
CON ' These are constants I include in most code I write because of there universality and usefulness.
'Clock ***May need to change this section depending on crystal being used***
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
'Timing
   clockfreq = ((_CLKMODE - XTAL1) >> 6) * _XINFREQ
   _1uS  = clockfreq / 1_000_000      'Divisor for  1 uS
   _1mS  = clockfreq /     1_000      'Divisor for  1 mS
   _1S   = clockfreq /         1      'Divisor for  1 S
'Serial Terminal
  STrxpin = 31
  STtxpin = 30
  STmode = 0
  STbaud = 9600 '***may need to change***
'Speaker ***Can Delete this section if not using piezospeaker***
  frequency_audible = 2093            ' 2093Hz. C7 note
  piezospeaker = 0 '***may need to change***
CON ProgramSpecific  ' These are constants that change depending on the rest of the program.
obj
   ' General routines
  Debug           : "FullDuplexSerialPlus"
  SqrWave         : "SquareWave"
PUB init ' Initialization Routine
  ' Piezospeaker Beeps for 2s then waits for 1/4s.
  '***Start of Piezospeaker code***
  SqrWave.Freq(0, piezospeaker, frequency_audible)
  waitcnt(clkfreq*2 + cnt)
  dira[noparse][[/noparse]piezospeaker] := outa[noparse][[/noparse]piezospeaker] := frqa := ctra := 0
  waitcnt(clkfreq/4 + cnt)
  '***End of Piezospeaker code***
  ' Activate and clear Serial Terminal
  Debug.start(STrxpin, STtxpin, STmode, STbaud)
  Debug.tx(Debug#CLS)
  StringToAscii
pub StringToAscii | index, stringptr  ' Run this to test the program. Good examples.
   Debug.str(string("Testing String To ASCII Code", Debug#CR))
   Debug.str(string("Number 8 in ASCII (should be 56) = "))
   Debug.Dec( Converter("8"))
   Debug.str(string(Debug#CR, "Letter A in ASCII (should be 65) = "))
   Debug.Dec(Converter("A"))
   Debug.str(string(Debug#CR, "Letter a in ASCII (should be 97) = "))
   Debug.Dec(Converter("a"))
   Debug.str(string(Debug#CR, "Should say hi there 9 times (in ASCII): "))
   stringptr := string("hi there 9 times")
  repeat strsize(stringptr)
    Debug.Dec(Converter(byte[noparse][[/noparse]stringptr++]))
    Debug.tx(" ")
  Debug.str(string(Debug#CR, "This is what the user should see: 104 105 32 116 104 101 ...(and so on)"))
  Debug.str(string(Debug#CR, "End of program", Debug#CR))
PUB Converter(sym) : ascii ' All Characters except
  case sym
    'Numbers
    'originally: 0..9 : ascii := sym + 48
    "1" : ascii := 48
    "2" : ascii := 49
    "3" : ascii := 50
    "4" : ascii := 51
    "5" : ascii := 52
    "6" : ascii := 53
    "7" : ascii := 54
    "8" : ascii := 55
    "9" : ascii := 56
    'Special Characters/Symbols
    " " : ascii := 32
    "!" : ascii := 33
    'skip "
    "#" : ascii := 35
    "$" : ascii := 36
    "%" : ascii := 37
    "&" : ascii := 38
    "'" : ascii := 39
    "(" : ascii := 40
    ")" : ascii := 41
    "*" : ascii := 42
    "+" : ascii := 43
    "," : ascii := 44
    "-" : ascii := 45
    "." : ascii := 46
    "/" : ascii := 47
    ":" : ascii := 58
    ";" : ascii := 59
    "<" : ascii := 60
    "=" : ascii := 61
    ">" : ascii := 62
    "?" : ascii := 63
    "@" : ascii := 64
    "[noparse][[/noparse]" : ascii := 91
    "\" : ascii := 92
    "]" : ascii := 93
    "^" : ascii := 94
    "_" : ascii := 95
    "'" : ascii := 96
    "{" : ascii := 123
    "|" : ascii := 124
    "}" : ascii := 125
    "~" : ascii := 126
    'skip delete
  case sym
    'Upper Case Letters
    "A" : ascii := 65
    "B" : ascii := 66
    "C" : ascii := 67
    "D" : ascii := 68
    "E" : ascii := 69
    "F" : ascii := 70
    "G" : ascii := 70
    "H" : ascii := 72
    "I" : ascii := 73
    "J" : ascii := 74
    "K" : ascii := 75
    "L" : ascii := 76
    "M" : ascii := 77
    "N" : ascii := 78
    "O" : ascii := 79
    "P" : ascii := 80
    "Q" : ascii := 81
    "R" : ascii := 82
    "S" : ascii := 83
    "T" : ascii := 84
    "U" : ascii := 85
    "V" : ascii := 86
    "W" : ascii := 87
    "X" : ascii := 88
    "Y" : ascii := 89
    "Z" : ascii := 90
    'Lower Case Letters
    "a" : ascii := 65 + 32
    "b" : ascii := 66 + 32
    "c" : ascii := 67 + 32
    "d" : ascii := 68 + 32
    "e" : ascii := 69 + 32
    "f" : ascii := 70 + 32
    "g" : ascii := 70 + 32
    "h" : ascii := 72 + 32
    "i" : ascii := 73 + 32
    "j" : ascii := 74 + 32
    "k" : ascii := 75 + 32
    "l" : ascii := 76 + 32
    "m" : ascii := 77 + 32
    "n" : ascii := 78 + 32
    "o" : ascii := 79 + 32
    "p" : ascii := 80 + 32
    "q" : ascii := 81 + 32
    "r" : ascii := 82 + 32
    "s" : ascii := 83 + 32
    "t" : ascii := 84 + 32
    "u" : ascii := 85 + 32
    "v" : ascii := 86 + 32
    "w" : ascii := 87 + 32
    "x" : ascii := 88 + 32
    "y" : ascii := 89 + 32
    "z" : ascii := 90 + 32
DAT 'Use what is bellow only as a reference (doesn't accutally do anything). This was a failed program I was working on.
CharactersTo47  Long  32,     33,  34,  35,  36,  37,  38,  39,  40,  41,  42,  43,  44,  45,  46,  47
'                     space   !     "   #    $    %    &    '    (    )    *    +    ,    -    .    /
Numbers  Long 48,  49,  50,  51,  52,  53,  54,  55,  56,  57
'             0    1    2    3    4    5    6    7    8    9
CharactersTo64  Long  58,  59,  60,  61,  62,  63,  64
UCLetters  Long 65,  66,  67,  68,  69,  70,  71,  72,  73,  74,  75,  76,  77,  78,  79,  80,  81,  82,  83,  84,  85,  86,  87,  88,  89,  90
'               A    B    C    D    E    F    G    H    I    J    K    L    M    N    O    P    Q    R    S    T    U    V    w    X    Y    Z
CharactersTo96 Long   91,  92,  93,  94,  95,  96
'                     [noparse][[/noparse]    \    ]    ^    _    `
LCLetters Long  97,  98,  99,  100,  101,  102,  103,  104,  105,  106,  107,  108,  109,  110,  111,  112,  113,  114,  115,  116,  117,  118,  119,  120,  121,  122
               'a    b    c    d     e     f     g     h     i     j     k     l     m     n     o     p     q     r     s     t     u     v     w     x     y     z
CharactersTo127 Long  123,  124,  125,  126,  127
'                     {     |     }     ~     DEL
{{ASCII Character Chart
32      space
33      !
34      "
35      #
36      $
37      %
38      &
39      '
40      (
41      )
42      *
43      +
44      ,
45      -
46      .
47      /
48      0
49      1
50      2
51      3
52      4
53      5
54      6
55      7
56      8
57      9
58      :
59      ;
60      <
61      =
62      >
63      ?
64      @
65      A
66      B
67      C
68      D
69      E
70      F
71      G
72      H
73      I
74      J
75      K
76      L
77      M
78      N
79      O
80      P
81      Q
82      R
83      S
84      T
85      U
86      V
87      w
88      X
89      Y
90      Z
91      [noparse][[/noparse]
92      \
93      ]
94      ^
95      _
96      `
97      a
98      b
99      c
100     d
101     e
102     f
103     g
104     h
105     i
106     j
107     k
108     l
109     m
110     n
111     o
112     p
113     q
114     r
115     s
116     t
117     u
118     v
119     w
120     x
121     y
122     z
123     {
124     |
125     }
126     ~
127     DEL
I was thinking that there must be a better way. Maybe with Assembly?
  • AribaAriba Posts: 2,697
    edited 2009-04-02 09:31
    Klap
    "a" is not a single character string, its the Spin notation for: Ascii value of a. So what you do here is compare each Ascii value
    with the Ascii value you have passed to the Convert methode and set then then Ascii value as return value. Or in other words you can write:
    PUB convert(sym) : ascii
      ascii := sym
    This methode makes not much sense, you pass the ascii value and return it. You simply can write:
       Debug.Dec("8")
    That's the same.
    Andy
  • MagIO2MagIO2 Posts: 2,243
    edited 2009-04-02 09:32
    What do you think about how ascii characters are stored?
    Asciis are just numbers which you give a different meaning.
    string byte $31,$35,$33,$30,$00
    is the same as
    string byte 48, 52,50,47,0
    and is the same as
    "1530"
    It's all a matter of interpretation of the numbers.
    So, your code is in the end doing nothing. It converts a number to itself with an expensive case statement.
    ascii := sym should do the same
    Your code is of course helpful if you want to convert an ASCII to another code. But then the easiest way is to use the lookup/lookdown SPIN commands.
  • Adrian SchneiderAdrian Schneider Posts: 92
    edited 2009-04-02 10:50
    besides what has been said, your Converter falsely converts numbers (I didn't check the other characters):
    the '0' is missing and the values for '1'-'9' are -1 off.
    regards
    adrian
  • jazzedjazzed Posts: 11,803
    edited 2009-04-02 18:18
    This reminds me of the day I discovered the "Singer code" in a Navy audio spectrum analyzer computer.
    Singer code was an octal based character set. The guy I worked for wouldn't tell me anything about it;
    I swear he was laughing under his breath while I was playing around with different bit combinations.
    Have a look at the Propeller Tool Help->View Character Chart. It shows ASCII and extentions of the Propeller font.
    One of the easiest ways to convert a character like 9 to a number in spin is:
    number := char - "0" ' if number > -1 and number < 10, it is a valid natural number
    Hex numbers can be derived the same way ... assuming char is lower case,
    hexnum := char - "a"
    You can use char |= $20 to force char to lower case ... this also preserves the number if it began as one.
    Google "ASCII code" to find more about this stuff.
    Enjoy your computing journey Klap.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
  • KlapKlap Posts: 65
    edited 2009-04-02 19:34
    Ohhh... I feel pretty "Special" now tongue.gif . I am not entirely sure what I was thinking when I was writing this program. I appreciate your insight into my laps of judgment. I am just glad I found out now before I showed this to my coworkers.
  • rjo_rjo_ Posts: 1,825
    edited 2009-04-02 20:29
    Klap...
    I'm with you... very special. I'm glad you asked and tonight when I actually get a chance to read it all, I'm going to enjoy it and learn a little.
    Rich
    edited 2009-04-02 20:31
    Sometimes things are easier than we think [noparse]:o[/noparse]) You could put the blame on fools day for that.
    ;0
