how can i use stamp plot lite without serial cable?
hello..
i need help on how to plot a graph with stamp plot with using serial cable. i use below program to get a temperature using ds1620.
i already set the threshold and can plot the graph using stamp plot.(program below is successful).
now, i want to plot the graph with using cable, i want to use a bluetooth as connection.in my project i need to tuse bluetooth to see the capanbilities.
i'm using eb500 bluetoth adapter for the transmission.
i hope anyone can help me with this problem..
thank you so much..
' {$STAMP BS2pe}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' This program measures temperature using the Dallas Semiconductor DS1620
' temperature sensor. Resolution is 0.5 degrees Celsius.
[noparse][[/noparse] I/O Definitions ]
DQ CON 3 ' DS1620.1 (data I/O)
Clock CON 2 ' DS1620.2
Reset CON 1 ' DS1620.3
[noparse][[/noparse] Constants ]
RdTmp CON $AA ' read temperature
WrHi CON $01 ' write TH (high temp)
WrLo CON $02 ' write TL (low temp)
RdHi CON $A1 ' read TH
RdLo CON $A2 ' read TL
RdCntr CON $A0 ' read counter
RdSlope CON $A9 ' read slope
StartC CON $EE ' start conversion
StopC CON $22 ' stop conversion
WrCfg CON $0C ' write config register
RdCfg CON $AC ' read config register
DegSym CON 186 ' degrees symbol
[noparse][[/noparse] Variables ]
tempIn VAR Word ' raw temperature
sign VAR tempIn.BIT8 ' 1 = negative temperature
tC VAR Word ' Celsius
[noparse][[/noparse] Initialization ]
Setup:
HIGH Reset ' alert the DS1620
SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]WrCfg, %10] ' use with CPU; free-run
LOW Reset
PAUSE 10
[noparse][[/noparse]Setting T_Hi]
HIGH Reset ' Tells the DS1620 that a command is coming.
SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]WrHi,$34\9] ' Command to set DS1620 TH to 32.
LOW Reset ' Completes the command cycle.
PAUSE 10
[noparse][[/noparse]Setting T_Lo]
SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]WrLo,$32\9] ' Command to set DS1620 TH to 31.
PAUSE 10
HIGH Reset
SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]StartC] ' start conversions
LOW Reset
Init_Graph:
DEBUG "!RSET", CR ' clear graph
DEBUG "!SPAN 25,35", CR ' disply 70 - 80 degrees
DEBUG "!AMUL 0.1", CR ' convert from tenths
DEBUG "!CLMM" ' clear min/max values
DEBUG "!TMAX 3600", CR ' 1 hour scale
DEBUG "!PNTS 60", CR ' graph every second
DEBUG "!MAXS", CR ' stop when graph full
DEBUG "!TSMP ON", CR ' enable time stamping
DEBUG "!TITL Temperature", CR ' set window title
DEBUG "!USRS Temperature in Celcius", CR ' graph legend
DEBUG "!CLRM", CR ' clear messages
DEBUG "Reset and monitoring temperature", CR' message box
DEBUG "!PLOT ON", CR ' enable plotting
[noparse][[/noparse] Program Code ]
Main:
'DO
GOSUB Read_DS1620 ' get the temperature
tempIn.BYTE1 = -sign ' extend sign bit
tC = tempIn * 5 ' convert to tenths
DEBUG DEC tC, CR ' send to Stamp Plot Lite
PAUSE 990 ' wait about 1 second
GOTO Main ' do it again
[noparse][[/noparse] Subroutines ]
Read_DS1620:
SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]RdTmp] ' give command to read temp
SHIFTIN DQ, Clock, LSBPRE, [noparse][[/noparse]tempIn\9] ' read it in
LOW Reset ' release the DS1620
RETURN
thank you so much..
' {$STAMP BS2pe}
' {$PBASIC 2.5}
Setup:
LOW Reset
PAUSE 10
PAUSE 10
PAUSE 10
HIGH Reset
LOW Reset
Init_Graph:
Main:
'DO
Read_DS1620:
RETURN
DEBUG XXXX
you will need to change that to
SEROUT 1,84,[noparse][[/noparse]XXXX]
You'll also need a 1000ms pause at the beginning of your program to allow the EB500 to initialize and you'll need a few statements to put the EB500 into data mode once the PC responds to the request for a Bluetooth connection. Follow the examples in the EB500 documentation.
You'll need to change the I/O pins you're using for the DS1620. The EB500 uses pins 0, 1 and 5, 6.
i've change the pin, the DEBUG to SEROUT and add data mode command. (as below)
but still cant get the graph plotted on the stamp plot.
is it wrong with the code or something?
i really need help with this..
TQ
'connect to remote device
SEROUT 1,84,[noparse][[/noparse]"con 00:0c:84:00:77:3D",CR]
SERIN 0,84,[noparse][[/noparse]WAIT("ACK",CR)]
'wait for the connection to be established and switch to data mode
waitForConnection:
IF IN5 = 0 THEN waitForConnection
HIGH 6
PAUSE 300
SEROUT 1,84, [noparse][[/noparse]"!RSET", CR] ' clear graph
SEROUT 1,84, [noparse][[/noparse]"!SPAN 25,35", CR] ' disply 70 - 80 degrees
SEROUT 1,84, [noparse][[/noparse]"!AMUL 0.1", CR] ' convert from tenths
SEROUT 1,84, [noparse][[/noparse]"!CLMM"] ' clear min/max values
SEROUT 1,84, [noparse][[/noparse]"!TMAX 3600", CR] ' 1 hour scale
SEROUT 1,84, [noparse][[/noparse]"!PNTS 60", CR] ' graph every second
SEROUT 1,84, [noparse][[/noparse]"!MAXS", CR] ' stop when graph full
SEROUT 1,84, [noparse][[/noparse]"!TSMP ON", CR] ' enable time stamping
SEROUT 1,84, [noparse][[/noparse]"!TITL Temperature Monitoring", CR] ' set window title
SEROUT 1,84, [noparse][[/noparse]"!USRS Temperature in Celsius", CR] ' graph legend
SEROUT 1,84, [noparse][[/noparse]"!CLRM", CR] ' clear messages
SEROUT 1,84, [noparse][[/noparse]"Reset and monitoring temperature", CR]' message box
SEROUT 1,84, [noparse][[/noparse]"!PLOT ON", CR] ' enable plotting
SEROUT 1,84, [noparse][[/noparse]DEC tC, CR]
This is my new program after the modification, but as before, stampplot unable to come out with the graph.
Note: I used DS1620 and pin connection as following:
DQ to PIN3
CLK to PIN2
RST to PIN1 - do I need to change any pin connected to DS1620? Pls advise... Thx
Program:
' {$STAMP BS2pe}
' {$PBASIC 2.5}
'Wait for the eb500 radio to be ready
PAUSE 1000 ' delay between readings,1000ms pause to allow the EB500 to initialize
waitForConnection:
HIGH 6
PAUSE 300
Setup:
LOW Reset
PAUSE 10
SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]WrHi,$40\9] ' Command to set DS1620 TH to 32.
PAUSE 10
SHIFTOUT DQ, Clock, LSBFIRST, [noparse][[/noparse]WrLo,$3E\9] ' Command to set DS1620 TH to 31.
PAUSE 10
HIGH Reset
LOW Reset
Init_Graph:
Main:
'DO
'DEBUG DEC tC, CR ' send to Stamp Plot Lite
Read_DS1620:
RETURN
I think you should first make sure your EB500 is connecting properly with your PC. Use the examples in the EB500 documentation to verify this. Once the EB500 is connecting properly, Stamp Plot Lite should work with the Bluetooth connection just like it works with a wired connection. I can't be of more help.
my eb500 is connect properly since i can read the temperature through hyper terminal using bluetooth.
but when i open the stampplot to get the graph, it wont display.
when i open the stamp plot, i disconnect the hyper terminal since it cant share same ports.
i cant figure out whats wrong since the connection through bluetooth to hyper terminal is successful..
maybe you have an idea?
TQ..
I don't know what's wrong with your setup. I don't have a lot of experience with either the EB500 or Stamp Plot Pro, but I know that you can do wireless Stamp Plot using xBee. Bluetooth is not very different. Once you've established a serial connection, it's really the same.
Thanks a lot for the help..
If anyone ever try this please let me know.
Until now i can get the stampplot connect with my pc through eb500,
just it wont plot the graph since my ds1620 wont give the temperature value.
I dont know whats wrong because if using cable ds1620 give the temperature reading..
Any idea or help are welcome..
TQ
