50 Mhz Crystal Recommendations
Hi, I have been having some difficulty getting a good 50MHz crystal for my SX20 project. I just ordered one from Mouser a week ago, but it isn't working properly. I varied up the capacitance and the clock settings in the source code. I am assuming I purchased the wrong type of crystal.
Does anyone have any Mouser or Digikey part numbers for a 50MHz crystal that definitely works?
How about any 50MHz ttl oscillators that definitely work?
Does it HAVE to be a crystal ? I use the 50MHz resonators from parallax and they work fine.
Leaded = http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/resonator/List/0/SortField/4/ProductID/360/Default.aspx
SMT = http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/resonator/List/0/SortField/4/ProductID/349/Default.aspx
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Right now I have a stack of the 50MHz resonators and they seem to work well.
I have two main issues though. I am using an SX20 in two different devices. Both require time-sensitive operations. One of the devices is powered from a wall wart. The other is battery powered. For the device from the wall wart I actually purchased a 50MHz oscillator, and that works amazingly.
For the battery powered device I need precision and low power. Plus the PCB layout is already on the way to the fab and I assumed the HC-49 50MHz crystal would work without a hitch. I may have hooked it up incorrectly, but it seems that the data sheet is specific about the type of 50MHz crystal that can be used with the SX chips.
I guess it doesn't have to be a crystal, but it would be best in my current situation.
Thanks again.
www.sxlist.com/TECHREF/ubicom/clocks.htm
9.0 Oscillator Circuits
9.1 A parallel resonant crystal type is recommended. Use of series resonant crystal is not recommended.
Fig. 9-1 shows the model crystal timebase circuit
Table 9-2 shows support component C,R values.
