Strange Math Problem (Resolved) — Parallax Forums
Greg LaPollaGreg LaPolla Posts: 325
edited 2009-04-02 00:49 in Propeller 1
I found this code in another thread for Steinhart Hart
PRI Calc_StHart (A,B,C,Resistance) : Kelvin | B_x_Rlog , C_x_Rlog , Rcubed, Rlog,  Addit
  G.start                                               ' Start math32
  Rlog := G.log(Resistance)                             ' Take the log of the Resistance
  B_x_Rlog := G.FMul(B,Rlog)                            ' Multiply B to log of R
  RCubed := G.FMul(Rlog,Rlog)                           ' Cube the log of R by R * R * R
  RCubed := G.FMul(Rlog,RCubed)                         ' Finish the Cube
  C_x_Rlog := G.FMul(RCubed,C)                          ' Multiply C to log the cubed log R
  Addit := G.Fadd(C_x_Rlog,B_x_Rlog)
  Addit := G.Fadd(Addit, A)                             ' Add all A,B,C together
  Kelvin := G.Fdiv(one,addit)                           ' Kelvin = 1/ all added
  G.stop
It always returns a negative number.
I put the above problem in mathcad(see attachment) and it calculates properly. Using the same numbers in the prop yields an answer of
-9.549217
Edit - Forgot to attach picture
Post Edited (Greg LaPolla) : 4/2/2009 2:54:06 AM GMT
625 x 986 - 74K
    edited 2009-04-01 22:53
    How are you providing A, B, C, Resistance? If one or more are not floating point values, that could explain what's happening.
  • Greg LaPollaGreg LaPolla Posts: 325
    edited 2009-04-01 22:57
    Here is how it is done
    CON
    Coeff1 = 0.0009461261                              ' Steinhart Constant
    Coeff2 = 0.00022226704                             ' Steinhart Constant
    Coeff3 = 0.000000105745286                         ' Steinhart Constant
    R1 = 10000
    repeat
        ohms := ((4095 * R1) / ADC.GetData(0)) - R1
        temp := Calc_StHart(Coeff1,Coeff2,Coeff3,ohms)
        updateLcd(ohms, temp)
        waitcnt(clkfreq / 5 + cnt)
    edited 2009-04-01 23:31
    Well, there you go ... The whole "ohms" calculation is in integer arithmetic. You may want to do that calculation in floating point or, at least, convert it to floating point.
    R1_Float = 10000.0
    R1_4095 = 4095.0 * R1_Float
    and
    ohms := FSub(FDiv(R1_4095,FFloat(ADC.GetData(0))),R1_Float)
    Post Edited (Mike Green) : 4/1/2009 11:40:51 PM GMT
    edited 2009-04-01 23:33
    Yup I discovered that after I posted the reply. I am reworking the steinhart routing to convert everything to float first.
    Thanks for the heads up!
    Greg
    edited 2009-04-02 00:24
    I have reworked the steinhart and now I have a new strange math problem
    PRI Calc_StHart (A,B,C,Resistance) : Fht | B_x_Rlog , C_x_Rlog , Rcubed, Rlog,  Addit, R_Float, Kelvin, Celsius
      Rlog := G.log(G.FFloat(Resistance))                   ' Take the log of the Resistance
      Celsius := G.Fsub(Kelvin,273.15)                      ' Convert to Celsius
      Fht := G.FMul(Celsius,1.8)                            ' Convert to Farenheight
      Fht := G.Fadd(Fht,32)
      G.stop
    The last calculation ( Fht := G.Fadd(Fht,32)) will not run.
  • TreeLabTreeLab Posts: 138
    edited 2009-04-02 00:48
    Change 32 to 32.0
    Cheers!
    Paul Rowntree
    That did the trick. Thanks
