Radio Shack IR detectors
Does anyone know how to wire a Radio Shack IR detector to a basic stamp?· I have several of the ones from Parallax that I know how to wire.· Those come with three connecting wires·(signal, ground and Vdd).· The ones from Radio Shack come with only two connecting wires.
I have had success with the IR phototransistors connected to a 555 timer being used as a Schmitt Trigger. It's one extra component, but they are cheap and available from Radio Shack also.
-Parsko
The IR detectors have additional circuitry built in that conditions the output signal in accordance with an input. The detectors work well to filter out ambient light effects/noise, such as flourescent (sp?) lights at 60Hz. They also require the emmitter to work at around 38-40kHz square wave.
If all you are doing is detecting a flag (counting revolutions, for instance), then my suggestion should work. You will not need the 38-40kHz square wave on the emitter with this setup (but could, I think, if you want).
What are you doing, btw?
-parsko
