How Can I Asing more than 1 byte to a ymbol (NOT an Array)
Hi this time my question is the following:
How can I asign more than ome byte in· run time to a symbol ex:
value := string("·· ")
t := strsize
In this case value should have 3 bytes asigned
How can I do the same without using the string command?
t := strsize
You can assign 3 characters like this: value := constant("A" | ("B" << 8) | ("C" << 16))
This puts the "A" as the first byte (lowest in memory) and a zero value as the last byte (highest in memory) in the LONG variable 'value'.
If you call 'dsp.str(@value)', then you'll see the characters "ABC" on the display. STRSIZE(@value) would be 3.
DAT
value byte 32,32,32,0
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
