Cheap Solar Cells to power Propeller
I was looking on Futurlec.com today for some stuff, and ran across these. It looks like you could easily string 3 or 4 of these cells together, and power the Propeller remotely, without batteries. The first thought that came to mind, was remote data logging out the the woods. Looks like you could do this for about $5-$8.
The low voltage units might be good when used in tandem with the buck/boost chip I talked about here.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
15W for $99.99 CAN
I had a friend mount pair of 210W panels and an Outback MX80 multistage regulator on his boat. This is an overkill for this but the concept is the same. The cells produce around 36V and the regulator inverts and steps down to between 13.1-14.4V (we use AGM batteries). This recovers about 20% extra from the cells because of the inverter (after losses).
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
They only put out 100uA each but are cheap and you can parallel them up around your circuit board
http://www.clare.com/Products/SolarCell.htm
tubular
that is the coolest thing I have ever seen. what can you do with 100uA though. how low of a draw can the prop possibly go?
Not really that cheap though. Digikey lists CPC1824 at $1.7064 CAN each for 25 at only 100uA each you need a few.
Post Edited (mctrivia) : 3/28/2009 1:54:52 AM GMT
Philldapill,
The best buy on that page is the 2V 92mA @ roughly 96.8 mW per dollar, however this would not be the best fit for the Propeller. The best fit for the Propeller, and the best Watt per dollar from that page would be the 3V 45mA @ 84.38mW per dollar.
mctrivia,
If you look hard enough for them you can find 15W panels for about $4 per Watt or $60 per panel .... Even cheaper ($2 per Watt) if you purchase $10K worth of them. (about 334 of the 15W panels) .... $10K really isn't terrible for a 5000 Watt system.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 3/28/2009 3:14:03 AM GMT
I still have about 400 of them.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
The best deal that I have spotted retail for panels is at Trackor Supply Co. They have a 4-15w panel package for $350. The price of these went up about 8 months ago from $300 so I can say that they are getting cheaper. They sell a single 15w panel for $150.
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
When you say that you can't improve the efficiency of solar panels, you are only half way correct. What you CAN do, is couple the panels to the load better. If you have a 30V panel, and you connect it to a 12V battery, the panel (probably) won't be working at peak output. The reason is simple. Any power source has a certain internal resistance. If the open circuit voltage of the panel is 30V, and you connect it to the 12V battery, the internal resistance will be dropping about 18V. Sure, you will be getting more current the lower voltage of the load, but the POWER transfered to the load is not at it's peak.
What you need, is a means of stepping down the voltage to a more appropriate value for the load, while at the same time, maximizing the current output of the solar panel. That is exactly what a buck/boost converter does. In a way, it acts as a transformer - stepping the voltage up/down, and at the same time, stepping the current down/up. A buck/boost converter is a very efficient means of providing 3.3V or whatever voltage for the propeller, or other electronics. The great thing is, you can take a wide range of voltages, and convert them to your target voltage with very little power loss. Try taking 12V, running it through a 3.3V regulator, drawing 500mA, and see how much of a burn you get when you touch it. Buck/Boost converters should be ice cold to the touch. [noparse]:)[/noparse]
For most solar applications, the buck/boost converter will be operating in the buck mode allowing for increased current at a lower voltage, while the boost mode allows for increased voltage at a lower current.
Keeping the leads short are important, but the voltage loss due to resistance is negligible when comparing to the internal resistance of the solar panel.
For example, if a Solar panel is rated for 15 Watts at 12V, then it's capable of supplying 1.25 Amps under load. The same panel might show 22V without any kind of a load.
In this case, the internal resistance would be about 8 Ohms... Compared to a 100 foot run of #16 wire would only contribute about 0.8 Ohms
You must also consider charging current... With the same setup mentioned above (15Watt 12V panel), if the battery was low, say 10.5V... the 10.5V battery would demand 1.44 Amps across the internal resistance of the panel. Since this is no longer at an optimal power rating of the Panel, the efficiency will drop off considerably. This is where the buck/boost converter will ultimately "kick in" and shine ... The panels want or like to be at their rated current and voltage... so in this case, the buck/boost converter would operate in the buck mode where it would be capable of delivering the lower voltage of 10.5V at a slightly higher current to meet the demand.... Still 15 Watts, but the current and voltage are adjusted accordingly via the buck/boost converter.
Beau Schwabe
IC Layout Engineer
At less than a dollar per watt, and in discrete cells, you can put together most any voltage/current you want. Since these have 2 tying lines on the front, you could slice them in half to get smaller cells for the same voltage if high current is needed. I don't know if you just need a glass cutter to do it, but it would be good to have a bunch of these around for little projects. They could even be encapsulated on the back side of your circuit board for a nice sturdy package.
Does anybody know where to get the clear stuff to encapsulate these like the ones from Futurelec?
Doug
I have tried making solar cells smaller in high school. Never succeeded though.
In the second example you have a starting system which is much more efficient to start. However I believe if you subtract the power that the Buck-boost consumes and increase the charge voltage to one that will actually work you will find that you are still loosing efficiency.
As for the length of wire and size make a big difference the higher the amperage it needs to carry. A 100' run of #16 at 8 amps will suffer a 3 volt drop. If you are trying to charge a 12v battery with 13.8 volts you will have too great of loss to do it. This is a good example of where a buck-boost will work nicely. You could increase the voltage so as to be able to achieve some charge rate. Again this example stems from an extremely inefficient setup whereas if a higher voltage panel or a more suitable wire where to be used to begin with you would achieve a higher efficiency compared to using the Buck-boost.
#10 at 30.5m(100') is 0.2036 ohms
@1.25A - Vdrop=0.2545V (minimum v=8.5V)
@8A - Vdrop=1.628V (minimum v=54.3V)
to use a 12V panel at 8A you need #1 wire that would be very expensive and that is just to be legal.
There is a reason I run all the lighting in big where houses like home depot at 347V and motors at 600V power loss is = IIR and I=E/R so doubling the voltage quarters the power loss.
You don't use the output of one converter, as the input of another converter. What I'm talking about doing, is switching to buck mode when the panel voltage is higher than what is needed, and boost mode when it is lower.
Secondly, many converters are upwards of 98% efficient. When you are talking abou gaining 20% more energy from the panel using a step-down/up method, the 2% loss is well worth it.
Your point about connecting a 30V panel to a 12V battery is sort of correct. If the panel puts out more current than the float current of the battery, yes, you will kill the battery ONLY after it has charged beyond the float voltage. If you have a car battery and connect a 15W 30V panel to it, the panel voltage will drop to the voltage of the battery. The only problem is AFTER the battery is charged, it will overcharge, damaging it.
Do some research on Maximum Power Point Trackers, or MPPTs. These do exactly this. They make a psuedo-load using a buck/boost sort of converter, and constantly watch the output of the panel. These devices essentially do a good job of matching the ideal load for the panel, extracting the peak amount of power from the panel.
In your third example, the BETTER way to charge the battery and lose the least amount of power, is to wire the panels in SERIES so that they make a higher voltage, lower current. Then, on your battery end, put a buck converter between the panel wiring and your battery to step up the current. It may not be for every application, but if the power lost in the buck is less than the power lost in the wires using your original method(high current, low voltage from panels), then go for the buck. Otherwise, just stick with the high current and eat the R*I^2 loss.
@Hinv You're right I stand corrected.
Solar-array controller needs no multiplier to maximize power
The circuit trick is two transistors in series that effectively generate a signal proportional to the power being drawn from the solar panel. That signal is used in the feedback loop of a buck-boost regulator to dither up to the maximum power point. No microcontroller needed. You have to have a load that is able to absorb that power, which is of course not always true in battery charging, and an output control loop is not implemented in the Design Idea.
The LTM4607 regulator used there claims to obtain an efficiency of up to 98% at certain voltage & current points. It will be a while before I use one though (LGA package).
I have a similar problem as FearTurtles with the efficiency issue. I use panels for low power instrumentation, and the time efficiency is most needed is on short winter days when there is only a few milliamps available. I don't want to through that away on the quiescent current of the regulator.
Tracy Allen
www.emesystems.com
Oh if anyone buys that Ebay item I would like to buy 10% of it off you if you can ship to Alberta, Canada at a reasonable amount.
