Prop Plug Grounding Issues
CassLan
Hi, I have a Dip Prop + Eeprom + Prop Plug connections hooked into a breadboard as described in page 17 of the Prop manual.
I can program the Prop just fine, however I feel that my circuit is somehow grounding via the PropPlug, I have some shift registers for outputs that drive LEDs and if I remove the power source, the LEDs stay very dimly lit until I unplug the PropPlug. I also had a similar oddity with·composite monitor that would not display clearly unless the PropPlug was connected. I have since switched to a DC powered composite monitor, and that seems to be working.
I would like to leave the PropPlug connected to the breadboard for programming, but I'm nervous about these occurances for fear of damage to the PropPlug or my USB Port, and also I want to know that my circuit will work with or without a PropPlug connected to it.
Has anyone had similar things happen? Should I be concerned?
Rick
Rick
The solution is to unplug the USB cable from the PropPlug when the Propeller setup is turned off.
The main problem is that the protective diode is not designed to handle more than about 1/2 mA of current, so it's not a good idea to leave things connected this way.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Rick
A non-open-drain buffer (e.g. 74LVC2G34) would solve the reset problem, but it would not eliminate the vestigial power to an unpowered Prop coming from a powered Prop Plug.
240-2389-1-ND - Ferrite
296-23277-1-ND - 74lvc2g07
Digi-Key Part Number - ft232rl(unfortunately not available in BGA)
will add to my next order. Still a little short of the $200 min for free shipping.
for hand soldering I recomend the JBC AD2700(discontinued) or similar. JBC soldering irons are more expensive but worth every penny. I have not yet replaced a tip and have replaced hundreads of weler tips. You can change tips while hot which is important because smt work requires different sized tips to work with different sized components and copper traces.
for reflow work. I recomend this Black and Decker Toaster Oven works perfectly for reflowing ICs and I managed to get on sale for half price.
Important things to look for:
Quartz heating element. low speed convections is preferable.
Post Edited (mctrivia) : 3/28/2009 2:47:35 AM GMT
