RE: Propellar Restart
schwiegjc
When I insert the USB cable from the Propellar (with it On) to PC, the Propellar will reset itself?
1) I've seen odd things where a circuit has ended up getting its earth/ground connection via the programming link to the PC. Which proto board are you using and how does it get its power.
2) Does your proto board have a reset switch on it? If it does, try repeating your experiments above but instead of attaching/disconnecting the PC try using the reset switch.
