Help with the new TASK function
HELP!!!
I’m building a component feeder using a SX48 and a LCD 20X4 serial display. The device uses a clock so I decided to use Jon’s Nuts and Volts code but replace the LED display. The clock works well (Tasks are great) but the LCD displays garbage…
Please look through this and tell me where I’m going wrong.
'CLOCKREFRESH - REFRESHES THE CLOCK DISPLAY
TASK LCDCLOCKREFRESH
··············· bank @CLOCK
···· Digit VAR byte
····· ········· LCDCMD LcdLine2Pos7
··············································· Digit = Hrs··························································································· ' Put Hrs to LCD
··············································· SWAP Digit
··············································· Digit = Digit + $0f
··············································· Digit = Digit + AsciiNo
····· ········· ··············· LCDOUT Digit
· ············································· LCDOUT colon
··············································· Digit = Mins······················································································· ' Put Mins to LCD
··············································· Digit = Secs························································································ ' Put Secs to LCD
···· ·········· ··············· LCDOUT Digit
· LCDCMD LcdLine3Pos8
ENDTASK
Regards from the Dark Continent
John Bond
···· Digit VAR byte
ENDTASK
John Bond
also I assume your AsciiNo is "0"
··············································· Digit = Digit &·$0f
··············································· Digit = Digit + "0"
That will give you "0" to "9" in Digit.
This only works if Hrs is stored as a BCD number.
regards peter
I should have known that!!!
Thanks also for the quick response and kind regards
John
