Propeller Accessories Kit — Parallax Forums
Dan TaylorDan Taylor Posts: 207
edited 2009-03-26 03:58 in Propeller 1
Hi:
I have got the Propeller Accessories Kit just recently. But I am having a little trouble. There is lots of coding for them but what about the connections? For instance the Display what do I plug it into? Please upload code and/or connections!
Thanks!
Dan Taylor
  • JomsJoms Posts: 279
    edited 2009-03-26 02:48
    I don't know if you already have the demo board, but I actually bought the education kit so it didn't have all the connectors. I don't know if this is what you are looking for or not, but take a look...
    http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropDemoDschem.pdf
    Also, Click the documentation radio button on the top of each file you have open, if it came from the object exchange it should have a schematic right on the top of the file.
    Hope this is of some help...
  • hover1hover1 Posts: 1,929
    edited 2009-03-26 02:57
    Dan Taylor said...
    Hi:
    Thanks!
    The Propeller Accessories Kit was designed with the the Propeller Demo Board in mind. The Demo Board has all the inputs for these items.
    See: http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropDemoDschem.pdf
  • Dan TaylorDan Taylor Posts: 207
    edited 2009-03-26 03:09
    I don't see the connections for the LCD. Am I just missing them?
    Could you please send me a line of code that shows me how to use them? I am used to BASIC and lines like PULSIN and SERIN but what do I use in Propeller?
    Dan Taylor
    Post Edited (Dan Taylor) : 3/26/2009 3:17:59 AM GMT
    edited 2009-03-26 03:20
    Dan Taylor said...
    The Propeller demo board is set up to output to a VGA monitor (15 Pin connector)··or Composite RCA Connector) (TV) signal.·The LCD should plug into the RCA Jack.
    edited 2009-03-26 03:41
    So I plug the LCD into the converter and then plug the yellow plug into the RCA Jack?
    Dan Taylor
    Post Edited (Dan Taylor) : 3/26/2009 3:53:38 AM GMT
    edited 2009-03-26 03:52
    Oh... I found out what the problem was... blush.gif I for got to plug the power into the Lcd. lol
    But now that I got it working the top 1/4 or so of the display is not showing the demo program. Do any of you know why this is?
    Thanks for all of the help!
    Dan Taylor
    Ooppss... Found out the problem again... There was a error in the code...
    Thank you all for helping me with this... I am very happy that I got it working!! hop.gif
    Dan Taylor
