BS2px and the pull-up resistor
Eagle1
Can anyone tell me why when a pull-up resistor is enabled on a I/O pin the pin goes high? Also I am especially interested in how the pull-up function is utilized in button circuitry. Thanx!
Mike2545
This message sent to you on 100% recycled electrons.
It's on the page of the BS1 but it will work for the BS2px as well.
Mike2545
Post Edited (Mike2545) : 3/26/2009 12:13:23 AM GMT
The I/O pin is where the input goes.
I'm not sure I understand what you are asking.
Mike2545
Eagle1
Mike2545
Here is the schematic for the BS2px.
I don't see the 20k resistors you are talking about.
Mike2545
Post Edited (Mike2545) : 3/26/2009 12:55:51 AM GMT
Eagle1
Mike2545
Mike2545
Eagle1
Mike2545
Eagle1
Mike2545
Eagle1
Mike2545
Eagle1
Mike2545
Eagle1
Accepts noisy input, where the threshold for logic 0 is approximately 15% of VDD and for logic 1 approximately 85% of VDD
Mode 1- logic threshold
CMOS level where logic 1 is 1.4 volts and logic 0 is below 1.4 volts
Mode 2- pullup
20k ohm pull up resistors logic 1 and 0 are split 50-50 between 5 volts
Mode 3-Output direction
Hope this helps
Mike2545
Thanks for the help, i get the picture now.
Eagle1
"you can remove the part of the schematic from VDD to after the button"
AKA the 10K resistor
"The signal is being pulled to the five volts on the I/O pin"
AKA the I/O pin is being held high or logic 1
Yes, that is correct. It will not be a dead short in the BS2px
Mike2545
Mike2545
