PIR Sensor
william chan
                    I find that the Parallax PIR sensor could sometimes be too sensitive when running at 3.3v
It may sometimes trigger about once in 30 minutes for no apparent movements.
Not all units exhibit this behavior.
Is there a way to reduce it's sensitivity?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
PG
·Is there anything that could be moving from an unexpected source; for example an A/C or heater turning on causing a breeze, a window open, or something similar? How are you tracking that there is movement? Can you post the code you have?
Respectfully,
Joshua Donelson
www.parallax.com
There is not much to the code as it just detects whether the output pin from the PIR is high or not.
Yes,
Sometimes the PIR sensor is about 2-3 meters away from a Air Cond. Will the A/C cause problems?
The other suspect I can think of is the noise from the boost regulator from 3v to 3.3v
I have been adding tantalum capacitors near the PIR sensor supply rails but it doesn't seem to help.
www.fd.com.my
www.mercedes.com.my
There has been an event where the PIR unit would detect the A/C unit turning on; but it was because it was moving a sign which triggered the PIR sensor. Is the pattern consistent for false triggers? Does it always seem to wait 30 minutes?
Respectfully,
Joshua Donelson
www.parallax.com
i TOO OBSERVED A SLUGGISH RESPONSE FROM THE SENSOR.
There should not be any difference in operation; the sensor can take up to a minute to adapt to the surroundings at first, is that that you are referring to? Or do you mean the triggering seems sluggish? Also, what trigger setting do you have the sensor set to; H or L?
Respectfully,
Joshua Donelson
www.parallax.com
Also the response was a bit sluggish. I tried both the settings (H and L) . I felt that it took some time to respond or change the signal in L mode.
I have not come across that with the PIR sensors that I have used; which have been with the BASIC Stamp (+5 VDC)·and the Propeller (+3.3 VDC). Which controller are you using with the PIR sensor?
Respectfully,
Joshua Donelson
www.parallax.com
