Can the voltage input to the Propeller Protoboard be greater than 9 volts?
Hi all,
I was looking over the spec sheet for the LM1086 voltage regulator, which I think is used on the Prop Protoboard. From what I think I understand, the LM1086 can take higher than 9 volts and still output the desired voltage of +5, or +3.3. If so, does that mean the Prop Protoboard could be operated with a +12 volt supply without any dramas? I'm asking because it might be nice to use the Vin hole on the board at +12 instead of merely +6 to +9. Am I showing my ignorance here, or is +12 a possibility?
thanks,
Mark
[noparse][[/noparse]Edited to fix version of board, sorry!]
Post Edited (ElectricAye) : 3/24/2009 6:37:48 PM GMT
thanks,
Mark
One thing to keep in mind regarding datasheet current ratings…that’s not the only specification you need to watch. Often the power dissipation is more important. In this case we’ve listed the input voltage based on the amount of heat the regulator will have to dissipate given the input voltage and current drawn by the device. With two regulators side by side on this board with no real thermal relief, the regulator will get hotter as it dissipates more heat from a higher input voltage. That’s not to say you can’t do it, but you should be careful about how much current you’re drawing at the same time so the regulators don’t get hot and shut down. I hope this helps. Take care.
[noparse][[/noparse]Edit: I was assuming you were referring to the Demo Board...if you mean the PPDB it is already rated for 12V]
Parallax Engineering
if you have any put some heat sinks on the regulator.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Sorry,
I'm talking about the Propeller Protoboard. I get confused about the different versions of boards.
Now I understand what you mean about the current draw/overall wattage passing through the system. My power needs are small, so I'm guessing it will be okay.
Thanks you guys, that is a big help!
For measurement I used a very non-technic approach, touching the voltage regulator with my index finger. As long as it doesn't get hot it's ok.
Also, has anyone had any experience mounting a heatsink over them?
I had a controller using the Protoboard where the 5V regulator would run hot and I wanted to reduce the temperature. I got a finned aluminum extrusion heatsink from RadioShack and glued it to the top of the regulators with some metal-filled epoxy cement ... not a huge blob, just covered the tops of the regulators with a thin layer, enough to fasten the heatsink and assure good broad contact. The particular heatsink nicely fit in the area on the board without touching anything else ... worked great.
Google is your friend:
http://www.google.com/search?sclient=psy&hl=en&site=&source=hp&q=LM1086+datasheet&btnG=Google+Search
the first link:
http://www.national.com/ds/LM/LM1086.pdf
Page 10 discusses the "Thermal Considerations" including determining the Junction to Ambient thermal resistance.
Ding: Sure I got google on my list, and the spec sheet too, thanks. However it doesn't state what the Rth-ja is, only Rth-jc so I was wondering what is the default (no heatsink) Rth-ca or Rth-ja in order to estimate if it would run ok with a 12V battery (13,8v when fully charged) and no other load (for the board) besides the protoboard and a couple of leds maybe.
The word "low" is not drawing a line but creates a safe zone, it depends... for instance serial LCD, gps, and some other stuff is ok, as long as I don't use back light....
Massimo
If you have some space left in your project you could put one of these very small fans to make the air moving over the regulator
a more easy way could be to add one or more regulators
example:
your inputvoltage is 24V then you could "line up" 18V-->---15V-->--12V-->--9V regulators
so each regulator has to drop only a small voltage and a small power as the complete power is distributed over the regulators.
But you have to keep in mind that the input-voltage has to be around 2V higher than the output-voltage
feeding 13V into a 12V regulator will not work properly.
best regards
Stefan
Sorry, I thought that you didn't have that datasheet. But for the regulator mounted on the board, it is soldered to the PC Board, which acts as the heat sink. So you can use the area of that portion of copper on the protoboard that holds the 5V regulator, and use the graph from the datasheet to get Rth-ha. Then the overall Rth-ja = Rth-jc + Rth-ch + Rth-ha. For a soldered connection to the board copper, the datasheet says to use 0 for Rth-ch.
Looking at a Protoboard image, I'd estimate the copper under the regulator as only about 90mm^2 (about 9mm x 10mm), which means there is a very high Rth-ha (not much area), probably well over 200 degreesC/W, from my eyeball interpolation of the graph.
Beyond that, I don't know enough to be of any more help -- not enough thermal experience.
Another option for attaching a heat sink is thermal tape. I have some but haven't tried it yet.
Thanks Ding, agree with you on the high Rth-ha and given that there's no spec for mounting the heatsink over the plastic side I'll give the epoxy a try and measure the temp.
Thanks to all respondents.
Regards, Alex
