Need help on multiple LEDs
I plan on making a small game system reminiscent of Evilmadscience's Peggy or Meggy Jr RGB, but with a BASIC Stamp II. However, I need to find a way to run say, 8 x 8 LEDs, which is 64 LEDs, each individually. The problem is that the BASIC Stamp II has only 16 I/O ports. Is there a way to make· an 8 x 8 LED array controlled with the·BASIC Stamp?
moderndevice.com/8X8display.shtml
Mike2545
This message sent to you on 100% recycled electrons.
Mike2545
Mike2545
Fwiss, Mike Green is right, I currently use two 74HC595's to drive 7 Segment Displays. Just a few days ago I had this same problem, I ran out of Pins on the Basic Stamp. I am now driving 13, 7 Segment Displays that's over 70 individual LEDs using only three stamp pins. Its really cool that you can drive that many leds with only 3 stamp pins. Good Luck. Let us know how it turns out.
Take a Look at these two posts.
http://forums.parallax.com/showthread.php?p=793684
http://forums.parallax.com/showthread.php?p=794704
They say if you Play a Microsoft CD backwards you can hear satanic messages, that's nothing because if you play it forward it installs Vista!
I didn't Fail 10,000 times, I simply found 10,000 ways that didn't work. -Thomas Edison
