Help with "VGA_1024x768_Tile_Driver_With_Cursor" driver. — Parallax Forums
BTXBTX Posts: 674
edited 2009-03-27 13:18 in Propeller 1
Hi all.
I'm trying to understand a bit more that driver.
And I can't found which is the relation of the array_ptr and the graphics setup code.
In fact I want to draw two or three big decimals digits at vga screen in differents positions. (differents colors if possible)
I can't deduce what to assign to @array variable, and how to configure gr.setup to have control in full screen.
I also try to modify the "VGA_Tile_Driver_Demo", to learn more...but I failed.
Thanks in advance for any help.
Regards.
Alberto.
  • RaymanRayman Posts: 16,383
    edited 2009-03-23 11:15
    There's some notes on the bottom of this page that might help:
    http://www.rayslogic.com/propeller/Programming/Programming.htm
  • BTXBTX Posts: 674
    edited 2009-03-23 11:32
    Thank you Ray.!!
    I'll look at them.
    Regards.
    Alberto.
  • BTXBTX Posts: 674
    edited 2009-03-26 21:17
    Hi Ray, or somebody.
    I did it what Ray suggest, and I can move the graphics screen by any place of the image, but......
    What about to resize the rectangle size for graphics ??? when I try it, I get some garbage added.
    gxt=32 '# graphics tiles in x direction (was 16)
    gyt=4 '# graphics tiles in y direction (was 8)
    w_x = 15'40 'left tile# of graphics window
    w_y = 3'30 'top tile# of graphics windows
    w_left = w_x * 16
    w_right = w_left + gxt*16 '256
    w_top = (48 - w_y) * 16
    w_bottom = w_top - gyt*16'128
    PUB start | i, j, k
    'start and setup graphics
    gr.start
    gr.setup(gxt, gyt, gxt*8, gyt*8, bitmap_base)'(16, 8, 16*8, 8*8, bitmap_base)
    'make some graphics tiles on the screen
    repeat i from 0 to (gyt-1) '7
    repeat j from 0 to (gxt-1) '15
    array.word[noparse][[/noparse]cols * (w_y + i) + j + w_x] := display_base + i*64 + j*gyt*64 + 21 'RJA}}
    Replacing qyt by a number greater than four, works me bad...
    What I'm not uderstanding in this ?
    I would like to use a full graphics screen. And also change that ugly background color.
    Thanks in advance.
    Regards.
    Alberto.
  • BTXBTX Posts: 674
    Sorry, anybody can help me ??
    Where can I found detailed documentation about how to use this driver ?
    limitations ??
    bitmap_base = $4000 why ??
    display_base = $6000 why ??
    Although in driver are explained array_ptr, how to understand why this ??
    array.word[noparse][[/noparse]cols * (w_y + i) + j + w_x] := display_base + i << 6 + j <<9 + 21
    Where is the 6 bit color ??
    Please I'm, stuck with this since a week.
    Regards.
    Alberto.
