SXB documentation extractor
Attached is·a small tool I wrote to extract documentation
from SXB sources.
When there is a tag '{$doc+} at column 1
all lines following that tag will be written to a .doc file
until a tag '{$doc-} at column 1 is encountered after
which lines are suppressed until another '{$doc+}
is encountered. Simple but effective as it allows
exactly what will be·written to the .doc file.
It is a commandline tool. You run it like
SXBdoc filename<enter>
If the filename contains spaces, enclose the filename in double quotes.
The extension .SXB is assumed and must not be given.
A file filename.doc will be generated.
Edit:
Also attached are two configuration files for the Crimson Editor (in SXBspec.zip).
Place those files in the Crimson folder spec.
When you load the .doc in the Crimson Editor, select
Document->Syntax Type->SXB
and you get colored comments and highlighted keywords.
You can then use a free pdf printer like pdf995 or primopdf
to print the documentation in full color.
regards peter
Post Edited (Peter Verkaik) : 3/22/2009 1:54:34 PM GMT
from SXB sources.
Edit:
regards peter
What/where/how is Crimson?
regards peter
for one of my libaries.
I am currently completing documentation for my
libraries and putting in the doc tags so only
public info and defined public constants appear in
the docs.
regards peter
