QTI Line Follower - Intersections — Parallax Forums
HuiHui Posts: 4
edited 2009-03-22 21:30 in Learn with BlocklyProp
Hey Parallax Community,
How are you? I'm a student at Duke University currently working on an electrical engineering design project. We are using BOE-bots to navigate along a path of electrical tape to certain "rooms". I have the basic movements of the QTI line follower going perfectly, but everyone is having trouble with the intersections. I've tried hard-coding the intersections, but this is often unreliable as varying batteries provide varying outputs for say, a FOR loop.
I was thinking that at an intersection you could have the bot rotate until the sensor no longer detects %111, at which point it would resume the SELECT process. However, since we're using counters to denote which intersection the bot is at, this often causes problems since the bot might go from %111 to %110 immediately back to %111, all at the same intersection (and thus messing up the intersection count).
Any ideas? I know this is really confusing, I can post that segment of my code if needed.
Thanks.
- Hui
    edited 2009-03-21 21:31
    Could you show us what you have so far? It would help to understand what your problem is and how you may circumvent it.
    - Stephen
    edited 2009-03-22 05:52
    Hui,
    Make your intersections with a "White spot" or hole in the middle and check for a "101" ... at this point ignore the left and right sensors and only look at the center sensor.· When the center sensor becomes a "1", then resume normal left and right sensing.
    With·a "solid" or filled intersection, if the BOE-bot comes in at an angle it will·"see" a "110" or "011" ... with the hole in the middle if the BOE-bot comes in at an angle it will "see" a "100" "001" and try to compensate for the error under the normal reading algorithm.· The "next" sample would be "101" which could be looked at in the algorithm as an ignore, but keep the current heading.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 3/22/2009 6:08:03 AM GMT
    863 x 871 - 23K
  • HuiHui Posts: 4
    edited 2009-03-22 18:44
    Hey all,
    Thanks for the suggestions. Beau, I would do that but we're not allowed to change the course [noparse]:([/noparse]. I think we have most of the code figured out now, but here's a copy, in case there's a much more efficient way of doing one of the functions:
    ' {$STAMP BS2sx}
    ' {$PBASIC 2.5}
    qti VAR Nib
    counter VAR Byte
    hashCount VAR Byte
    timeCount VAR Byte
    counter = 0
    hashCount = 0
    timeCount = 0
    DO
    GOSUB checkSensors
    SELECT qti
    CASE %000 ' Not on a track - Forward
    GOSUB forward
    CASE %101 ' Stuck - Forward
    GOSUB forward
    CASE %010 ' Forward
    GOSUB forward
    IF hashCount = 3 THEN ' Goes forward into the room, then backs out of the room
    counter = counter + 1
    IF counter = 10 THEN
    FOR timeCount = 0 TO 5
    GOSUB rightangleRight
    NEXT
    ENDIF
    ENDIF
    CASE %011 ' Pivot right
    GOSUB rightPivot
    CASE %001 ' Rotate right
    GOSUB rightRotate
    CASE %110 ' Pivot Left
    GOSUB leftPivot
    CASE %100 ' Rotate Left
    GOSUB leftRotate
    CASE %111 ' Intersection
    GOSUB intersection
    ENDSELECT
    PAUSE 20
    LOOP
    'Various subroutines
    checkSensors:
    Right: HIGH 5: PAUSE 1: qti.BIT0 = IN3: INPUT 5
    Center: HIGH 6: PAUSE 1: qti.BIT1 = IN3: INPUT 6
    Left: HIGH 7: PAUSE 1: qti.BIT2 = IN3: INPUT 7
    RETURN
    forward:
    PULSOUT 13, 2125
    PULSOUT 12, 1625
    PAUSE 100
    RETURN
    rightPivot:
    PULSOUT 13, 2125
    PULSOUT 12, 1875
    PAUSE 100
    RETURN
    rightRotate:
    PULSOUT 13, 2125
    PULSOUT 12, 2125
    PAUSE 100
    RETURN
    leftPivot:
    PULSOUT 13, 1875
    PULSOUT 12, 1625
    PAUSE 100
    RETURN
    leftRotate:
    PULSOUT 13, 1625
    PULSOUT 12, 1625
    PAUSE 100
    RETURN
    intersection:
    IF hashCount = 0 THEN 'Intersection at the front of parking space
    ELSEIF hashCount = 1 THEN 'Intersection of the middle of parking lot
    GOSUB rightangleLeft
    ELSEIF hashCount = 2 THEN 'Intersection of path with room
    ELSEIF hashCount = 3 THEN 'Rotates 180
    ELSEIF hashCount = 4 THEN 'Turn left out of the room
    ELSEIF hashCount = 5 THEN 'Path 1, 2, 3
    ELSEIF hashcount = 6 THEN 'Path 1, 2, 3 exit - must be same as hashCount = 5
    ELSEIF hashCount = 7 THEN 'Parking space
    GOSUB forward
    NEXT
    GOSUB forward
    NEXT
    ENDIF
    hashCount = hashCount + 1
    RETURN
    rightangleRight:
    FOR timeCount = 0 TO 3
    GOSUB forward
    NEXT
    DO
    GOSUB rightRotate
    GOSUB checkSensors
    LOOP UNTIL (qti.BIT0 = 0) AND (qti.BIT1 = 1) AND (qti.BIT2 = 0)
    RETURN
    rightangleLeft:
    GOSUB forward
    NEXT
    DO
    GOSUB leftRotate
    GOSUB checkSensors
    RETURN
    Hui,
    Another idea... If you spread out your Left and Right sensors out a little bit (trial and error) by pivoting them on their connecting screw, then "normal" line reading should only be %000, %100, %010, and %001. If an intersection is detected, then the returned value could be %110, %111, or %011 in which case you would ignore the adjustment for steering correction and make note you are in an intersection.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 3/22/2009 9:35:42 PM GMT
