74hc595
MR
I ran out of pins on the Basic Stamp 2P40. I need to drive common anode 7 segment displays, is it possible to use a 74HC595 shift register to accomplish this purpose? If it is possible do I need a different type of transistor? I use common anode displays and currently I have the 3906 transistors.
If it Stinks it is Chemistry
If it is Mushy its Biology
If it doesn't work its Physics
If it Gooey its Biology
They say if you Play a Microsoft CD backwards you can hear satanic messages, that's nothing because if you play it forward it installs Vista!
I didn't Fail 10,000 times, I simply found 10,000 ways that didn't work. -Thomas Edison
640 KB is all the memory anyone will every need. -Bill Gates in a 1980's interview talking about Windows.
In 1969, the crew of Apollo 11 landed on the moon. A standard calculator has more computing power than the Apollo 11 computer, yet it takes almost 3 Gigs to Run Vista. Something is wrong here!
thanks for the info
I HAVE LEARN SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=296-1954-5-ND
························ Craig Eid
··········· Triad Research and Development
Electical Engineering Design and Consulting Services
··················· www.TriadRD.com
Post Edited (Craig Eid) : 3/22/2009 7:38:31 PM GMT
