Exceeding Longs
Once again, I'm fairly new to the Propeller Chip, but have been coding for quite a long time.
This time, I'm trying to develop a platformer game on the Hydra. (Ooh, scary.) But, I'm usually used to being able to code stuff in separate parts, but then combine everything in one file. This has sort of become a problem, because although I'm working with the largest chip Parallax offers, I'm still having problems with the file exceeding memory by x amount of longs.
The weirdest thing is that I would have one file that says has 3,000 or so longs available, yet when I add a single line of code, it says it exceeds it by say, 200 longs.
So, anyone know of any sort of larger chip or a way around this problem? This project is kinda big, and would help me tons with any other projects, so any help would be appreciated.
Thanks!
~Komaru
Thanks!
~Komaru
2) There may be things you can do to reduce the amount of space your program uses. You'd need to post your program as an attachment to a message (Do Not Cut and Paste a large program into a Message!)
3) If your program can be split into several separate programs, you might be able to use an SD card or a large EEPROM to store what are essentially overlays.
The EEPROM was what I was talking about, not the actual Propeller Chip. Sorry for the misunderstanding.
But I'll try out the SD card reader.
There's not really much to actually post of my program, as it's just some text and music in the background- Which is why I was confused about it running out of memory.
Well thanks again for your help, I'll make sure to keep a lookout for a larger EEPROM card.
There's another "propDOS" available that does the same sort of thing using files on an SD card. FemtoBasic and its derivatives can also run Spin or assembly programs from an SD card in addition to interpreting simple Basic programs.
I'm pretty sure I still have FemtoBasic somewhere, so I'll try that.
