PULSOUT question
Theory says that the Parallax/Futaba continuous rotation servos must be pulsed at 1.3ms for full CW, 1.7ms for full CCW and 1.5ms to stand still.
That is the equivalent of PULSOUT pin, 650 / PULSOUT pin, 750 / PULSOUT pin, 850 with the standard BS2 2microsecond rule.
However, I've seen code that uses PULSOUT pin, 600 and PULSOUT pin, 900 to drive these servos - and even the servo manual (PDF on this site) says that.
Is this safe? Is this a mistake? Is this pushing the limits?
Thanks.
Thanks.
PG
