My last question for my project!!!
Can someone please help me!!! This is like the last part of my project and I can't figure it out I tried posting this question on the "Stamp" category but things didn't work out...
My problem: I need to increase the voltage of a I/O pin which is currently at·5V to about·8V
I am trying to·put one of the I/O·pins' voltage into a·741 noninverting amplifier that multiples the voltage. I understand the configuration·BUT THE PROBLEM IS THE V-. I don't·know·how to get the negative voltage from a I/O pin or from anywhere else for that matter...·If I could figure out the V+ and V- aspect of the 741 Op Amp then I can finish my project. I don't know how to get the V- using the stamp configuration or what to do to get it... I don't know!!!
Any ideas how to·use the voltage·comming from·an I/O pin and putting it through some type of circuitry that makes the voltage about twice or three times or·maybe adding 5 volts to it?? This is the last part of my project so it is really getting to me!!!·Please HELP me·or I will cry... seriously...and i'll be out of your hair for good (probably)
Please Help me!!!!!!!
I·have two 741 op amps so why don't I use one as an inverter and feed the output to the second op amp that is non-inverting and get the result I wanted!!!... and i've been trying that for almost 3 hours now... but it hasn't worked either... lol...*sigh*
Post Edited (kwinn) : 3/21/2009 4:24:59 PM GMT
Jax
ps.. Make sure you zoom up on it at least 1200% to read it, sorry for that.
If a robot has a screw then it must be romoved and hacked into..
