What's wrong with this Propeller?
Ken Peterson
Hi all,
I have a Propeller Protoboard with a problem. To test it, I run the following program on it. It basically clocks all of the pins high and low at 0.5 Hz. I use this program all the time to check suspect Propellers for proper pin operation.
When I run the program on this particular Protoboard, I get a constant voltage of 0 - 1.7V (depending on the pin) except for pins 28 and 29 which are at a constant 3.3V. The funny thing is that it loads the program, programs and verifies the EEPROM all without error, but after the program is loaded I don't see the output on the pins as expected - including pins 28 - 31.
Any ideas what's wrong with it?
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
Post Edited (Ken Peterson) : 3/20/2009 6:14:48 PM GMT
CON _clkmode = RCFAST pub main dira[noparse][[/noparse]31..0]~~ repeat waitcnt(clkfreq+cnt) !outa[noparse][[/noparse]31..0]
- Bjarne Stroustrup
When something like this happens to me, it's usually one of three things:
1. The programming cable is actually plugged into another board,
2. I hit F9 instead of F10 or F11 (old BASIC Stamp habit),
3. The scope probe is lying on the bench instead of being clipped onto a signal.
Post Edited (Phil Pilgrim (PhiPi)) : 3/20/2009 6:23:05 PM GMT
We've had this exact thing happen with two or three Protoboards for no apparent reason. I've put together numerous custom boards and hand-soldered the Propellers (44 QFP) down, and I didn't have this happen to any of them. Seems pretty strange to me.
If I use RCFAST, would this rule out a bad PLL?
BTW: I watched the display (loading, programming eeprom, verifying.. etc.) so I didn't hit the wrong key. It's plugged into the right board because it's the only board on my desk. And I'm using a DMM to check the pins so I'm sure that's connected.
- Bjarne Stroustrup
Post Edited (Ken Peterson) : 3/20/2009 6:28:04 PM GMT
I think you're getting a bus conflict on pin A31, which causes the Prop to draw too much power, causing a brownout and a subsequent reset. Try excluding pins A28-A31 and see what happens.
Post Edited (Phil Pilgrim (PhiPi)) : 3/20/2009 7:09:10 PM GMT
smbaker:· I also had the test program running at a higher frequency using the crystal.· I scoped the crystal and saw 5MHz on both pins.· I am running the test program on RCFAST hoping to rule out a bad PLL.· The boot loader runs on RCFAST because not all Propellers have a crystal on them.
- Bjarne Stroustrup
Post Edited (Ken Peterson) : 3/20/2009 7:25:42 PM GMT
- Bjarne Stroustrup
I·was using the flux pen from spark fun. I know it sounds wierd but i tested the conductivity of the flux by just painting a little on soem cardboard·and even when it basically dried i was getting like 100k ohms
It was driving me nuts.
OOPS sorry i see this is a propeller proto board your talking abotu not a custom board.... so probably ignore this post [noparse]:)[/noparse]
Jesse
I don't do much Prop Programming (tempus fugit), but (1) What is cnt initialized to? Also, I would initialize the pins to some known state:
outa := $AAAAAAAA
And if I was really desperate, simply put a repeat (loop forever) after the outa command.
HTH,
--Rich
Wild thought: Are you using the USB protoboard? If so, toggling A30 and A31 like you're doing will repetitively reset the Prop if the USB cable is unplugged.
The 3.3V on 28 and 29 is what you would expect from pullup resistors. What do you measure on all the pins when you hold the reset in? As a normal step simplify you code down to a single pin and confirm that works first then stage up until you hit a problem (could be a short).
*Peter*
I do think all of the pins are inputs for some reason, but what's stumping me is why the boot loader program is running with no apparent problem but nothing else works. I tried toggling only pins 28 and 29 and that didn't even work. How is it programming the EEPROM?
- Bjarne Stroustrup
