Question about using an Op AMP??!11!!!
Can someone please help me!!! This is like the last part of my project and I can't figure it out!!
I am trying to·put one of the I/O·pins' voltage into a·741 noninverting amplifier that multiples the voltage. I understand the configuration·BUT THE PROBLEM IS THE V-. I don't·know·how to get the negative voltage from a I/O pin or from anywhere else for that matter...·If I could figure out the V+ and V- aspect of the 741 Op Amp then I can finish my project. I don't know how to get the V- using the stamp configuration or what to do to get it... I don't know!!!
Any ideas how to·use the voltage·comming from·an I/O pin and putting it through some type of circuitry that makes the voltage about twice or three times or·maybe adding 5 volts to it?? This is the last part of my project so it is really getting to me!!!·Please HELP me·or I will cry... seriously...and i'll be out of your hair for good (probably)
BTW, this is the first hit on a Google search for "741 Op Amp"
Duffer
