Does anyone know how to use a gpio trigger to interface with the input of a BS2?· I'm trying to build a pulse inverter using GPIO triggers as the input source and causing a logic low on my output.
Can you provide more information in regards to what you are using? Are you using a button as a trigger or what general purpose I/O trigger that you are using.
Respectfully,
Joshua Donelson
www.parallax.com
